Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Xolo
Old 12-24-2014, 07:59   #1 (permalink)
Member: 1754544
Sonork: chetan
Thanks Meter: 20
XOLO Q1100 IMEI NULL After Flash
Please friends and experts i have a XOLO Q1100 which is come to me for forgot security password....i try to reset but every time demanding password so i flashed it and after flash IMEI NULL ....now what can i do ....how to rebuild OR get back......please any solution need urgentely
Old 12-26-2014, 20:21   #2 (permalink)
Member: 2317582
I am facing the same problem. but i managed to get one of the two imei no. using efs professional tool.
Old 12-27-2014, 08:23   #3 (permalink)
Member: 1754544
Sonork: chetan
Thanks Meter: 20
Procedure to use efs professional tool
Please explain how to do this.........with efs professional tool.... i need it badely please urgent
Old 12-27-2014, 08:41   #4 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Hello,
can you tell me cpu of phone and which firmware you used to flash ?
and software details from the backside of phone ?
Old 12-28-2014, 09:47   #5 (permalink)
Member: 2317582
download efs professional(google it).
Install all the drivers of the phone in your computer.
connect your phone to pc and open efs pro.
go to qualcomm nv tools. there select your com port by checking in device manager.
Mine was com4.
Then click connect.
go to secure ops tab.
there check the imei box and write your imei no.
Select target phone.
now click write.
it will give a confirmation msg.
Thats it. But it is for only imei1 but imei2 is still unkown.
The Following User Says Thank You to uuvraj For This Useful Post:
Old 12-28-2014, 13:13   #6 (permalink)
Member: 1754544
Sonork: chetan
Thanks Meter: 20
Xolo q1100 ic = msm8228
Old 08-03-2015, 19:53   #7 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 240
Restore your IMEI 1 and IMEI 2 (No Signal Fix)(Invalid IMEI)
1. Dial *#*#3646633#*#* (EngineerMode)
2. Swipe from right to left once.
3. In Connectivity Tab Press CDS Information
4. Press Radio Information
5. In Phone Information tab and Press Phone 2 and
type/add EMGR=1,10,"(YOUR IMEI 2 HERE)" and press SEND AT COMMAND.
6. Reboot
7. REPEAT Step 1-4
8. In Phone Information tab Enter Phone 1 and
type/add EMGR=1,7,"(YOUR IMEI 1 HERE)" and press SEND AT COMMAND.
9. Reboot
10. To check if you have a valid IMEI dial *#06#
Note:
Follow the instructions carefully.
Your IMEI 1 and IMEI 2 are indicated on the back of battery case.
Old 11-14-2015, 08:55   #8 (permalink)
Member: 2486704
Xolo q1100 imei repaired!!!!!!
I repaired the imei of xolo q1100. It was a very typical task but yet i am happy i repaired it myself!!!
Contact me on +91XXXXXXXXXX to know how to repair imei of xolo q1100 or any phone having qualcomm chipset!
The Following User Says Thank You to shivansh19802 For This Useful Post:
Old 11-15-2015, 08:46   #9 (permalink)
Member: 1962832
Thanks Meter: 199
Thumbs up xolo q1100 imei null success 100000%
use this tool:GN_QC_EG_WRTIMEI_V1.2.0 - Download - 4shared
Old 11-15-2015, 12:20   #10 (permalink)
Member: 1962832
Thanks Meter: 199
xolo q1100 imei repair tool
Welcome to the ./downloads/Gionee/Drivers & Tools/Qualcomm IMEI Writing Tool/ folder of GsmHosting support area
Old 12-04-2015, 13:57   #11 (permalink)
Member: 1224654
Sonork: jaheer
Thanks Meter: 61
how can connect phone? with off mode or on mode? pls help
Old 12-05-2015, 18:37   #12 (permalink)
sb99sameerkhan's Avatar
Member: 1978625
Sonork: 100.1661449
Thanks Meter: 39
how to use this tool off mode on mode how
Old 12-14-2015, 15:45   #13 (permalink)
AFZALHASMI's Avatar
Member: 304342
Thanks Meter: 20
yes brother done this tool GN_QC_EG_WRTIMEI_V1.2.0 tested thksssssssss
Old 12-27-2015, 05:45   #14 (permalink)
Member: 1503859
Sonork: 100.1672251
Thanks Meter: 43
after flash xolo q1100 dead solution only show qualcomm hs usb qdloader 9008 any body help me urgent please..............
Old 02-09-2016, 15:33   #15 (permalink)
Member: 2043715
thanks its works but after enter wifi mac add
Page generated in 0.24937 seconds with 8 queries
