03-04-2014, 08:00 | #126 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2140230 Status: Offline Thanks Meter: 0 | celkon a900 flash file link problem please reupload file in other link. you are the only hope PLzzzzzzzz upload it in mega AND IF possible tell me the procedure to install that rom . I have bricked that phone and you can only alive my phone pleeeeeeeeeease upload the rom |
03-11-2014, 14:27 | #128 (permalink) |
No Life Poster Join Date: Jul 2010 Location: chennai, india
Member: 1354113 Status: Offline Thanks Meter: 669 | Volcano Updated: 2014-02-20 Connecting... Connection successful,connected state! Version: V3.8 SN:234-171-783 Port:COM5 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM1 COM5 Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Analyzing USB device, please wait... Find USB device:SCI USB2Serial (COM12), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100040] Flash ID: 002C00BC90555600 Flash Type:[Micron] MT29C4G48MAZAPAKD FLASH LEN:0x20000000 >>File partition was not found. |
03-18-2014, 09:14 | #130 (permalink) |
Insane Poster Join Date: Jun 2008 Location: visakhapatnam
Member: 786547 Status: Offline Sonork: 100.1645883 Thanks Meter: 8 | celkon A20 hard reset --- volume up and power button then u will see no command click power button and use volume up key to select option... |
03-19-2014, 12:35 | #131 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Heaven Age: 35
Member: 2141811 Status: Offline Thanks Meter: 38 | Celkon AR50 4.4 KitKat ROM. The Celkon AR50 owners may also want to keep their device up-to-date. So we thought of giving you a tutorial of how to upgrade Celkon AR50 to Android 4.4 KitKat. With new version of android operating system on your device, you will have more benefit. Your device will have more feature, more secure, more fast performance, and more cool he...3x. But prior to telling you how to install Android 4.4 KitKat on Celkon AR50, let’s see what do you want in order to be able to perform the installation. You will have to download 4.4 KitKat Celkon AR50 ROM. You will also have to root your Celkon AR50 to prepare it for Android 4.4 KitKat upgrade. Discover how to root Celkon AR50 and install Android 4.4 KitKat from here. Here are the download links of the files you want to update Celkon AR50 to Android 4.4 KitKat. Just before beginning to upgrade your Celkon AR50 to Android 4.4 KitKat don’t forget to backup your information, as contacts, text messages and the apps installed from Google Play Store who maybe lost when the installation finishes. Now let’s see how to update Celkon AR50 to Android 4.4 KitKat : 1. Install the ROM Manager on your Celkon AR50. Get it from Google Play Store, then install the clockwork mod recovery. 2. Connect your Celkon AR50 to your PC employing the USB information cable. Copy the “ROM.zip” file you downloaded to the SD memory card. 3. Restart your device in the recovery mode using ROM Manager. As soon as in Recovery Mode, go to ROM Manager and select backup / restore to back-up your information. 4. From the Recovery Menu do a total data erase (including Delvik Cache). When completed, go back to Recovery Principal Menu and choose Flash ROM from SD Card. Navigate the location you copied the ”ROM.zip” file and follow the directions for installing Android 4.4 KitKat on your Celkon AR50. As soon as the installation is over, just reboot your Celkon AR50 device, and here you go, you’ve just upgraded it to the new Android 4.4 KitKat. Note: Here Is Link To Download the ROM = The ROM File size is 128 MB, so I split the file into 3 parts : ROM Part 1 : Link ROM Part 2 : Link ROM Part 3 : Link To combine 3 parts files above into 1 file just use WINRAR, then extract the files into ZIP format. If any problem with the ROM, maybe because the ROM have corrupted during the download process, you can try to re-download the ROM. Thank you for visiting Celkon AR50 4.4 KitKat ROM |
03-19-2014, 12:39 | #132 (permalink) |
Member: 2141811 Status: Offline Thanks Meter: 38 | |
