Lenovo General Lenovo phones discussion, firmwares, solution, help |
02-16-2018, 00:26 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | added pass Hi, Flash Lenovo_K33_FRP_by_bRkA with QFIL Flasher. All necessary drivers are in QFIL archive. archive pass: forum.gsmhosting.com Instructions : - Install Drivers - Put phone into download mode : Power off device, press down Volume UP Key and then connect USB cable with PC, release key after vibrating. The device get into Diagnostics 9091 mode first, then click “download” item on device - Select port for QDLoader 9008 in QFIL tool. - Select "Flat Build" - Select programmer - "prog_emmc_firehose_8937_ddr.mbn" - Select "Load XML" and select "rawprogram0.xml" and "patch0.xml" - Press "Download" and wait for successful finish. After flashing, enter recovery and do "Wipe data / Factory reset", then reboot. FRP Should be gone after that. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 03-16-2018 at 23:44. |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
03-16-2018, 23:46 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Updated original post. Password is: forum.gsmhosting.com b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
