Lenovo General Lenovo phones discussion, firmwares, solution, help |
10-18-2017, 21:35 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Download all needed (Drivers, factory flasher, flash file) : TB3-7703X_S000137_160830_ROW TB3-7703X_S000225_170606_ROW - Install Andy_plus_driver_V1.0.2 - Install Lenovo_USB_Driver_1.1.33_Setup - Unpack archive, and move content from \SW folder in MultiFlash folder (Multiflash\images) - Start MultiFlash as administrator - Put device in fastboot mode - Hold volume down + Power on button until "fastboot" displayed - Connect to pc - Download should start, progress in yellow text, and finish with green "pass" text. - After starting, set region code - ###682# - After region code is applied, fully reset phone b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 04-15-2021 at 22:43. Reason: fixed info's |
The Following 6 Users Say Thank You to Brka For This Useful Post: |
10-19-2017, 05:35 | #3 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | all done as you said but but always fail to download calculating 4% to 9% and says failed **** EDIT: finally done via fastboot command thank you Last edited by Brka; 10-19-2017 at 20:13. Reason: merged posts |
02-17-2018, 13:01 | #5 (permalink) |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | extract the rar file and paste this bat file and run it https://www.4shared.com/file/L4wqFcv1ei/flash_all.html |
07-08-2018, 03:37 | #6 (permalink) |
Junior Member Join Date: Jul 2018
Member: 2849565 Status: Offline Thanks Meter: 0 | same problem, 4% then 9% then fail! I tried the solution but its just flashing the files and sometimes cmd goes into like a loop of waiting devices and all, Bottom line - it isn't working for me so please could you fix it for me. |
07-08-2018, 12:52 | #7 (permalink) |
Member: 2849565 Status: Offline Thanks Meter: 0 | so, finally it worked. I was able to flash a stock rom to my tb-7703x, but another problem occured. seems like radio is not working, i'm not able to do any activites or use any of the wireless features, like, wi-fi, bluetooth, radio, etc. |
04-15-2021, 22:44 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | fixed. refresh page, download. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
02-04-2022, 06:25 | #12 (permalink) |
Junior Member Join Date: Jan 2022 Location: Saltillo Age: 20
Member: 3005993 Status: Offline Thanks Meter: 0 | Has anyone fond a fix for the internet services not working After flashing the ROM, WiFi, Bluetooth don't turn on Does someone knows if it's possible to fix this ? |
