Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 06-24-2020, 19:39   #1 (permalink)
Member: 2853099
Thanks Meter: 3
Bootloader unlock verizon HTC ONE M7
Trying to unlock bootloader, get message that token has been calculated but phone not accepting the token. Help please.
Old 06-27-2020, 16:37   #2 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
You might have tried it already, but try to reboot the phone and repeat the process.
Also you can S-OFF it, which gives you more options and does not require your data to be erased.
Old 06-27-2020, 21:07   #3 (permalink)
Member: 2853099
Thanks Meter: 3
writing 'unlocktoken'... FAILNot support on this device!
FAILED (remote: Not support on this device!)
finished. total time: 0.147s
htc_fastboot finished
Error: The unlock token was not accepted by the phone. Try to re-calculate it again.
This is the message i get. is this phone not supported? Its a verizon M7.
Old 07-03-2020, 23:46   #4 (permalink)
Member: 2853099
Thanks Meter: 3
Hello team....no response? Please help resolve the issue.
Old 07-04-2020, 17:01   #5 (permalink)
Member: 2416253
Thanks Meter: 4,162
Some firmwares have BL unlock turned off, or "OEM unlock" is disabled in developer settings.
As I said - your better option is to S-OFF .
Old 07-06-2020, 01:00   #6 (permalink)
Member: 2853099
Thanks Meter: 3
Even the S-OFF is not working. Says sd initialization fal. I am using a brand new y cable.
Old 07-10-2020, 03:33   #7 (permalink)
Member: 2853099
Thanks Meter: 3
Hello...no more support from the tea to resolve issues?
Old 07-10-2020, 03:34   #8 (permalink)
Member: 2853099
Thanks Meter: 3
Old 07-12-2020, 19:05   #9 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
Unfortunately we can't be any helpful if you have a problem with Y-cable.
Y-cable can be tricky in most cases, if you have another cable - just try it. In most cases the problem was in faulty Y-cable. Have you ever successfully tried it on another phone?
Old 07-24-2020, 17:37   #10 (permalink)
Member: 2853099
Thanks Meter: 3
Hello,
The s-off worked but bootloader unlock still not working. Problem was with sd card reader not the y cable. Any solution for the bootloader?
Old 07-24-2020, 18:41   #11 (permalink)
Member: 2416253
Thanks Meter: 4,162
It's probably can be done using direct editing of the partition, but in fact you don't need it - since your phone is S-OFF you can flash any custom firmware.
Can I ask why do you insist on the bootloader unlock? There are absolutely no advantages of the bl unlock over S-OFF.
Page generated in 0.16232 seconds with 8 queries
