06-28-2017, 15:54 | #4 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ then copy files again and repeat. | |
06-28-2017, 16:52 | #5 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | Quote:
06-28-2017, 19:06 | #6 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Are you sure that you copy files for your model? Please kindly send me a list of files that you have on your clip. P.P.S. Do you connect clip to the phone? Make sure your clip is detected by your phone, you can check it in download mode, if all ok, then reboot to ftm. |
06-28-2017, 19:35 | #7 (permalink) | ||
Member: 19723 Status: Offline Thanks Meter: 359 | Of course ! Yes . Quote:
bl.txt factory htc58diag SMART_IO.CRD | ||
06-28-2017, 21:28 | #9 (permalink) | |
The clip is seen by the computer . Sent from my HTC Desire 820 using Tapatalk | |
06-29-2017, 10:39 | #10 (permalink) | |
1. Repair filesystem (http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/) 2. Replace flex. | |
06-29-2017, 13:31 | #11 (permalink) | |
Why should I replace the flex as long as the computer sees my xtc clip ? (it's hard for me to get a new one) | |
06-29-2017, 13:36 | #12 (permalink) | |
If you don't have spare flexes (you should have at least 2 with XTC 2 Clip), then I don't know how to help, the only advice I can give, is to try to insert the clip again and again unless it will be detected by the phone. | |
