03-21-2019, 22:46 | #1 (permalink) |
Crazy Poster Join Date: Aug 2017
Member: 2743735 Status: Offline Thanks Meter: 0 | HTC 10 Unlock Issue I'm trying to Unlock a Verizon HTC 10 on Android 8.0. Using the special unlock for HTC 10, I connected the SD to the computer, copied the files successfully then tried booting the phone into ftm mode, but it just restarts. The message still says there's a non-verizon sim and the screen still says locked. Phone screen imgur (dot) com /XdKivVU Program screen imgur (dot) com /7jHZZkd |
04-12-2019, 17:37 | #8 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Please provide your firmware version / phone information. I'll check the exact steps in your case and let you know. | |
04-16-2019, 22:02 | #11 (permalink) |
Member: 2743735 Status: Offline Thanks Meter: 0 | Here is what I get Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_pmewl (bootloader) version: 1.0 (bootloader) max-download-size: 1578400000 (bootloader) serialno: FA7870100377 (bootloader) slot-count: 0 (bootloader) current-slot: (bootloader) imei: 990007192175674 (bootloader) version-main: 3.18.605.13 (bootloader) boot-mode: download (bootloader) version-baseband: 2.0.C010252@71226 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PS650000 (bootloader) cid: VZW__001 all: finished. total time: 0.016s htc_fastboot finished Reading CID information ... (bootloader) cid: VZW__001 OKAY finished. total time: 3.613s htc_fastboot finished Reading MEID information ... (bootloader) meid: 99000719217567 OKAY finished. total time: 0.000s htc_fastboot finished Reading IMEI1 information ... (bootloader) imei: 990007192175674 OKAY finished. total time: 0.016s htc_fastboot finished Reading IMEI2 information ... (bootloader) imei2: OKAY finished. total time: 0.016s htc_fastboot finished Reading secure flag information ... (bootloader) Device security level S-ON, reboot count 0 OKAY finished. total time: 0.016s htc_fastboot finished Reading serial number information ... (bootloader) Device Serial No. is FA7870100377 OKAY finished. total time: 0.016s htc_fastboot finished Reading color information ... (bootloader) COLOR ID: BLK00 OKAY finished. total time: -0.000s htc_fastboot finished Read information completed. |
04-17-2019, 16:05 | #12 (permalink) | |
Reading secure flag information ... (bootloader) Device security level S-ON, reboot count 0 Your device is S-ON. You cannot boot to FTM in this state. Please do this: 1. Connect clip to SD slot of your phone. 2. Insert PowerAdapter into the clip and connect it to your PCs usb port. 3. Run XTC 2 Tool, open "PowerAdapter" tab. 4. Reboot phone to donwload mode, make sure you have "SD MOUNTED" message on the phone now. 5. Press "Write security" having S-OFF (0) selected as an option. 6. Wait for the process to finish. Reboot phone to download mode and confirm it's S-OFF now. Once done, process with "Special unlock / IMEI" as instructed there (same FTM mode way as you tried). Once the phone is unlocked, you can S-ON again if you want. | |
The Following 2 Users Say Thank You to xtc2clip For This Useful Post: |
