09-19-2020, 17:19 | #1 (permalink) |
Junior Member Join Date: Aug 2019 Location: India
Member: 2922699 Status: Offline Thanks Meter: 2 | HTC 10: Warning! Your phone does not see the XTC 2 Clip [SOLVED] It keeps showing "SD NOT MOUNTED", and XTC2Clip gives a "FAILPERMISSION DENY (NOT_FIND_SMART_IO)" error. - XTC2Clip in the SD card reader for PC works fine - drive is detected - Tried all 3 flex cables; they work in the PC, not in the HTC10 - I'm using the SD card sled that came with the phone; sd card is 100% aligned properly in the phone. - Tried "Clip filesystem repair" option; no luck I read another post that had the same problem with HTC10; Has anyone had success with this phone? Any ideas what I can try next? Here's my logs: 1. Checking phone connectivity...... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage.. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 FAILPERMISSION DENY (NOT_FIND_SMART_IO) FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO)) finished. total time: 0.053s htc_fastboot finished Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Operation completed! Releasing adapter. Request completed |
The Following User Says Thank You to botnet For This Useful Post: |
09-23-2020, 15:25 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | HTC 10 / U11 SD NOT MOUNTED solution HERE please https://r.tapatalk.com/shareLink/top...ink_source=app Sent from my iPhone using Tapatalk |
09-25-2020, 16:00 | #3 (permalink) | |
No Life Poster Join Date: Dec 2015
Member: 2494408 Status: Offline Thanks Meter: 110 | Quote:
change flex cache Sent from my iPhone using Tapatalk | |
