11-26-2017, 19:50 | #1 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2618036 Status: Offline Thanks Meter: 2 | Error htc u 11 S-OFF 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 FAILPERMISSION DENY (DENY) FAILED (remote: PERMISSION DENY (DENY)) Execution time is 11(ms) Operation completed! Releasing adapter. Request completed WRITE CID 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writecid 11111111 ... FAILWRITE CID PERMISSION ERROR FAILED (remote: WRITE CID PERMISSION ERROR) Execution time is 7(ms) Operation completed! Releasing adapter. Request completed WRITE MID 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writemid 2PZC50000 ... (bootloader) [ERR] Command error !!! OKAY Execution time is 7(ms) Operation completed! Releasing adapter. Request completed I have the phone with Oreo android with the firmware 2.31.709.1, connected the xtc in the sd of the phone together with the power adapter connected to the pc, I will be doing something wrong or is it the firmware? regards |
11-26-2017, 20:44 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, No, it's not the firmware, because according to the log, the software does not connect to the server to obtain data. Please contact me on skype, I want to check myself the process to be able to help: xtc2clip |
The Following User Says Thank You to xtc2clip For This Useful Post: |
12-05-2017, 03:30 | #7 (permalink) |
Member: 2618036 Status: Offline Thanks Meter: 2 | It does not work for htc u11 with Android Oreo ..... @ XTC2CLIP and you do not give solution It does not work for htc u11 with Android Oreo ..... @ XTC2CLIP and you do not give solution It does not work for htc u11 with Android Oreo ..... @ XTC2CLIP and you do not give solution Last edited by xtc2clip; 12-07-2017 at 18:45. |
