HTC Desire 530 Unlock Problem " Failed to Enable SIMLOCK " [SOLVED] HTC Desire 530 is giving error on Unlocking. Unlock Bootloader is DONE Phone S-OFF is DONE Custom Recovery is DONE. When I put phone is FTM Mode and press SIMLOCK TOOL , it says : " Chosen_item 2 Loading simlock tool ... Failed to enable SIMLOCK " I have tried couple of time, even with xtc clip i copied specail files couple of times, but still showing error. Picture Attached " http://i1362.photobucket.com/albums/...psnad1zz4c.jpg" What is the solution ??? LITTLE MASTER |
Hello, You don't need to use this. Please use "Special unlock/IMEI" tab. |
I insert clip in sd card off phone and press FTM phone phone went to same as picture |
It means that files are not copied correctly, clip ejected too quick or no safe removal was done. Try to repair FS: http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ then copy files again, do Safe eject and then insert into phone and press "FTM". This should work. |
Unlock this device is easy no needed special Knowledge to unlock this device... First tick OEM unlock, Unlock Bootloader, Flash TWRP, Boot to Bootloader, Reboot Recovery, in TWRP do a S-OFF, Copy Special/IMEI tab HTC Desire 530, Power off phone, Insert Clip in phone, Power on phone using Volume up and power 5 seconds, realease power button, but volume up pressed, phone enter to mode Diag after that the phone reboot automatically and you phone is unlock sim card done... |
same issue even after repair and format file system and i tried sprint tab nothing worked |
The Memory Chip we insert inside the phone was not going in properly. I changed that strip and redone whole procedure , It worked like Charm. So I suggest you to change this strip and MAKE SURE its going 100% inside the phone . https://ae01.alicdn.com/kf/HTB14ZTcJ...pg_640x640.jpg LITTLE MASTER |
http://i1362.photobucket.com/albums/...psnxr2e7gz.jpg LITTLE MASTER |
After all, i tried to go another way, software unlock, then i found this thread, Which is for 626 but it works on 530 without a single change, You may want to give it a try, Solution tested by me, and everything is working great, My phone was locked at T-Mobile if you should know, Best Regards |
I have this problem http://forum.gsmhosting.com/vbb/atta...1&d=1535065546 |
