Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 10-08-2015, 10:05   #31 (permalink)
Member: 2416253
Thanks Meter: 4,162
Download link:
https://mega.nz/#!H8dxXIaS!NrbJieIJd..._lYfDqR8SlfvaE
Old 10-10-2015, 21:34   #32 (permalink)
Member: 1810649
Sonork: GunShoot
Thanks Meter: 8
Originally Posted by xtc2clip View Post
hi how install this flash in htc desire 626s metropcs??????
Old 10-12-2015, 00:28   #33 (permalink)
Member: 958481
Thanks Meter: 2
S-off, locked bootloader, oem unlocking on
From Download mode
fastboot flash zip F:\Downloads\0PM9IMG_A32E_UL_L51_DESIRE_SENSE70_HT C_LA_SPA_1.09.599.2_Radio_01.01_U113251011_32.04.5 0622G_2_release_444097_signed_2_4.zip
target reported max download size of 724000000 bytes
Invalid sparse file format at header magi
error: write_sparse_skip_chunk: don't care size 477099212 is not a multiple of t
he block size 4096
sending sparse 'zip' (707028 KB)...
he block size 4096
he block size 4096
OKAY [ 43.452s]
writing 'zip'...
(bootloader) HOSD CL#573731
(bootloader) ERR lzipv2_init : Cannot open file /dev/fastboot_download_1
(bootloader) lzq9U
(bootloader) ERR cannot allocate memory(10240 KB) for loading ZIP file '
(bootloader) /dev/fastboot_download_1lzq9U'
(bootloader) end@Done
FAILED (remote: 12: fail to flash via downloadzip)
finished. total time: 45.513s
fastboot oem rebootRUU
he block size 4096
he block size 4096
he block size 4096
OKAY [ 43.452s]
writing 'zip'...
(bootloader) lzq9U
Old 10-12-2015, 11:35   #34 (permalink)
Member: 2416253
Thanks Meter: 4,162
Please use updated fastboot:
https://mega.nz/#!CxE2TJab!W7VETtd54...6o6T8yt-bEjGUM
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 10-13-2015, 07:17   #35 (permalink)
Member: 958481
Thanks Meter: 2
one step closer, now asks for code with new firmware but still not unlocked
deleted everything off of the card itself
using 1.12 chose 626s option, rebooted with card in blinks white trying to go to ftm, hangs for a sec, boots then asks for unlock code
Old 10-13-2015, 16:42   #36 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello. I tried once again and it worked fine. So just try once again and it should be fine.
Old 10-13-2015, 22:46   #37 (permalink)
Member: 1810649
Sonork: GunShoot
Thanks Meter: 8
how install firmware???
please help me
Old 10-14-2015, 10:26   #38 (permalink)
Member: 2416253
Thanks Meter: 4,162
please help me
htc_fastboot.exe flash zip <filename.zip>
Phone must be in download mode.
Old 10-14-2015, 15:59   #39 (permalink)
chavonbravo's Avatar
Member: 952912
Thanks Meter: 142
Hello. I have metro branded 626s as well, and have put the unbranded firmware file successfully onto the device. Afterwards, I have retried twice to unlock via xtc2clip. I boots to ftm mode, get a white screen with some words on top for a very short time, that I cannot read (looks like old legacy mode white screen for clean s58). Then it goes black screen for a few seconds, then reboots. After reboot, it still asks for unlock code. I tried 00000000 as code, still doesn't work. Any suggestions? I believe the unlock hash is located in rfg_8 partition. If someone with unlocked 626s could dump the first two sectors (1024 bytes) of this partition, I could compare to my locked hash. Command for this would be "fastboot oem read_mmc emmc 383546 3 1 1". Only works in fastboot bootloader mode, not in download mode, by the way.
Old 10-14-2015, 16:06   #40 (permalink)
Member: 2416253
Thanks Meter: 4,162
1. S-OFF phone (if not yet)
2. Repeat the unlock process 2-3 times, sometimes it may fail, but as nothing is displayed on the screen, we can't find what's going on.
3. There is no unlock hash in HTC, only lock flag. Code cannot be recovered. So reading rfg_8 won't help you.
Old 10-14-2015, 16:13   #41 (permalink)
Member: 952912
Thanks Meter: 142
Phone is already s-off, or would not have accepted unbranded firmware. I have repeated many times, with original metropcs firmware, then with tmobile firmware, then with cricket firmware, then with your posted firmware. If you look here: Sim Unlock. Free!! - CONFIRMED WORKING | HTC One (M9) | XDA Forums , you will see that for unlocking the m9, that is all they changed. When unlocked, it has a different hash, but same for all unlocked. Locked for all gsm m9 also have same hash there. I thought maybe it was same for this model. Can't hurt to check as a possibility.
Old 10-14-2015, 16:26   #42 (permalink)
Member: 2416253
Thanks Meter: 4,162
see pm please
Old 10-14-2015, 16:59   #43 (permalink)
Member: 952912
Thanks Meter: 142
I have tried "fastboot erase rfg_8", and it does clear it all out. (0x00's). As soon as phone boots up, it puts the same hash there as before (locked hash). Also have tried to write arbitrary 1024 bytes, to see if it sticks through reboots, and it does, it doesn't revert to original hash. So I'm confident that if someone dumps their unlocked 626s rfg_8 partition via "fastboot oem read_mmc emmc 383546 3 1 1", I can create the rfg_8.img file, and simply flash it as "fastboot flash rfg_8 rfg_8.img", then reboot, and it should be unlocked.
The Following User Says Thank You to chavonbravo For This Useful Post:
Old 10-20-2015, 01:44   #44 (permalink)
Member: 958481
Thanks Meter: 2
did you have any luck with this?
Old 10-20-2015, 23:01   #45 (permalink)
Member: 952912
Thanks Meter: 142
Yes. Worked quite well.
Page generated in 0.23776 seconds with 9 queries
