07-31-2017, 18:12 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2694036 Status: Offline Thanks Meter: 2 | HTC E8 question When I got the HTC E8 it was s-offed and so I tried to flash any ruu for it but it gave me id error as if it wasent s-offed so I tried s-offing the device but still same problem it says in bootloader that this device is s-offed but doesnt act like it is |
08-01-2017, 18:51 | #3 (permalink) |
Member: 2694036 Status: Offline Thanks Meter: 2 | Thanks for the reply! I used the flash function in the xtc 2 clip software tool to try and flash this device here is the log: Starting flash process... found large-zip header, file count: 7 processing file 1/7... sending 'zip' (47317 KB)... OKAY [ 2.328s] writing 'zip'... (bootloader) zip header checking... (bootloader) shift signature_size for header checking... (bootloader) zip info parsing... (bootloader) checking model ID... FAILED (remote: 41 model id check fail) finished. total time: 2.656s Flash process completed. |
08-02-2017, 09:42 | #4 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Or, at least, post model ID which is printed on the back of the phone. | |
08-02-2017, 10:31 | #5 (permalink) |
Member: 2694036 Status: Offline Thanks Meter: 2 | Good morning, Here is the Model Number info on the back of the phone: Model: OPAJ100 M8Ss And here is my getvar info: (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.25.213311711.23G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.33.708.6 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: xxxxxxxxxxxxxx (bootloader) imei: xxxxxxxxxxxxxxxxx (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: mec_tl (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0PAJ1**** (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: bf08371e (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Many thanks! Last edited by josephnoble; 08-02-2017 at 10:38. |
08-02-2017, 11:45 | #6 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Thanks! You need to use flash files for 0PAJ1, please search for 0PAJ1 on the support, and download the flash file you need. For example we have same version as your phone - 2.33.708.6, which is file no. 448589 |
The Following User Says Thank You to xtc2clip For This Useful Post: |
08-02-2017, 18:24 | #7 (permalink) |
Member: 2694036 Status: Offline Thanks Meter: 2 | Thank you! The zip flashed! Unfortunately the problem I had still remains the device doesnt seem to recognise sim cards although the sim tray and device seem to be in very good condition. Would you recommend any other actions? I have tried flashing the stock rom Many thanks |
08-03-2017, 16:30 | #8 (permalink) | |
Are you sure there is no reaction when the sim is inserted? Is it sim-unlocked phone? | |
08-03-2017, 16:57 | #9 (permalink) |
Member: 2694036 Status: Offline Thanks Meter: 2 | Yes the phone is sim unlocked there doesnt seem to be any sign of recognition of the sim at all not even saying that you have to unlock the device before the sim. The device and the sim tray's physical condition seem to be excellent. Also this device used to accept sim cards but it was returned from a friend and now doesnt |
08-03-2017, 19:10 | #10 (permalink) | |
Please try latest firmware (via direct flash or OTA). Maybe there was a liquid inside, it's now not visible, but already affected the slot/contacts/pcb. | |
