12-10-2019, 18:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ~Lemuria~
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | HTC M9 Impossible Flashing [SOLVED] Log in Recovery Mode: Reading information... Using ADB mode... Chipset: *[msm8994] Memory: *[3GB] Hardware: *[htc_hima] Serial no: *[HT5BGYJ00491] Signed: *[test-keys] Android version: *[5.1.1] Device: *[htc_himaul] /sbin/sh: dumpsys: not found Running as: root Read information completed. +++++++++++++++±+++++++++++++ Log in download/Fastboot Mode: Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himaulatt (bootloader) version: 1.0 (bootloader) serialno: HT5BGYJ00491 (bootloader) current-slot: (bootloader) imei: 359234567890092 (bootloader) version-main: 4.25.598.1 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U11440971_103.00.61018G_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA11000 (bootloader) cid: HTC__332 all: finished. total time: 0.026s htc_fastboot finished Reading CID information ... (bootloader) cid: HTC__332 OKAY finished. total time: 0.082s htc_fastboot finished Reading MEID information ... (bootloader) meid: OKAY finished. total time: 0.010s htc_fastboot finished Reading IMEI1 information ... (bootloader) imei: 359234567890092 OKAY finished. total time: 0.010s htc_fastboot finished Reading IMEI2 information ... (bootloader) imei2: OKAY finished. total time: 0.010s htc_fastboot finished Reading secure flag information ... (bootloader) Device security level S-ON OKAY finished. total time: 0.010s htc_fastboot finished Reading serial number information ... (bootloader) Device Serial No. is HT5BGYJ00491 OKAY finished. total time: 0.010s htc_fastboot finished Reading color information ... (bootloader) COLOR ID: DEF00 OKAY finished. total time: 0.010s htc_fastboot finished Read information completed. |
12-10-2019, 18:41 | #2 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Phone Stuck on Logo This Roms: No work 0PJAIMG_HIMA_UL_L50_SENSE70_ATT_HTC_LA_AMX_SPA_1.4 1.598.2_R4_Radio_01.01_U11440221_62.05.50320G_F_re lease_444938_signed_2_4 0PJAIMG_HIMA_UL_L51_SENSE70_ATT_MR_HTC_LA_SPA_2.11 .599.21_Radio_01.02_U11440601_77.04.50715G_2_F_rel ease_449477_signed_2_4 0PJAIMG_HIMA_UL_L51_SENSE70_ATT_MR_HTC_LA_SPA_2.11 .599.180_Radio_01.02_U11440601_77.04.50715G_2_F_re lease_464560_signed_2_4 0PJAIMG_HIMA_UL_M60_SENSE70_ATT_MR_HTC_LA_SPA_3.42 .599.2_Radio_01.01_U11440801_97.04.60111G_F_releas e_471145_signed_2_4 0PJAIMG_HIMA_UL_M60_SENSE70_ATT_MR_HTC_LA_Telcel_S PA_3.44.600.1_Radio_01.01_U11440801_97.04.60111G_F _release_473182_signed_2_4 Last edited by 69eyes; 12-10-2019 at 18:48. |
12-10-2019, 18:42 | #3 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | This Roms: No work 0PJAIMG_HIMA_UL_L50_SENSE70_ATT_HTC_LA_AMX_SPA_1.4 1.598.2_R4_Radio_01.01_U11440221_62.05.50320G_F_re lease_444938_signed_2_4 0PJAIMG_HIMA_UL_L51_SENSE70_ATT_MR_HTC_LA_SPA_2.11 .599.21_Radio_01.02_U11440601_77.04.50715G_2_F_rel ease_449477_signed_2_4 0PJAIMG_HIMA_UL_L51_SENSE70_ATT_MR_HTC_LA_SPA_2.11 .599.180_Radio_01.02_U11440601_77.04.50715G_2_F_re lease_464560_signed_2_4 0PJAIMG_HIMA_UL_M60_SENSE70_ATT_MR_HTC_LA_SPA_3.42 .599.2_Radio_01.01_U11440801_97.04.60111G_F_releas e_471145_signed_2_4 0PJAIMG_HIMA_UL_M60_SENSE70_ATT_MR_HTC_LA_Telcel_S PA_3.44.600.1_Radio_01.01_U11440801_97.04.60111G_F _release_473182_signed_2_4 |
12-10-2019, 18:44 | #4 (permalink) |
12-10-2019, 22:43 | #6 (permalink) |
Freak Poster Join Date: Jan 2012
Member: 1713460 Status: Offline Thanks Meter: 28 | man, just s-off and supercid your phone. after flashing you can revert it's CID and security state, if it is needed |
The Following User Says Thank You to nick_fc For This Useful Post: |
12-10-2019, 23:01 | #7 (permalink) | |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Quote:
Hi Man! Always error. Thanks USB CABLE FROM PC TO PHONE XTC CLIP 2 TO PC + POWER ADAPTER (Without Y cable) + USB TO FROM POWER ADAPTER TO PC Log: 1. Checking phone connectivity...... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage.. Phone connection confirmed! HTC KEY CARD VERSION: 6 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writecid 11111111 ... FAILWRITE CID PERMISSION ERROR FAILED (remote: WRITE CID PERMISSION ERROR) finished. total time: 0.016s htc_fastboot finished Operation completed! Releasing adapter. Request completed | |
12-15-2019, 17:13 | #10 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello Sir! On your first photo you can see in the first lines that the phone doesn't see XTC 2 Clip. Either it's not attached properly, or it was attached when the phone was already in the download mode, simply reboot to download mode once again and make sure that you see "SD MOUNTED" message on the phone's screen. As to the second photo - the phone can now detect the clip, but there is a problem with the xtc2 smartcard. Do you have it inserted correctly? If you believe so, kindly eject it, gently clean with a rubber or soft cloth and insert back. Let me know if this helped. |
The Following User Says Thank You to xtc2clip For This Useful Post: |
12-17-2019, 20:52 | #11 (permalink) |
Member: 1713460 Status: Offline Thanks Meter: 28 | Use standard smartcard in xtcClip instead of powerAdapter. xtcClip must be connecterd to SD slot, after this - reboot download and try to use "direct mode" tab in xtc2tool instead of "power adapter" tab. press Write security 0. when s-off - press write CID |
12-20-2019, 21:31 | #12 (permalink) | |
xtc 2 clip inside phone: Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 6 FAILPERMISSION DENY (NOT_FIND_SMART_IO) FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO)) finished. total time: 0.000s htc_fastboot finished Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Operation finished xtc 2 clio inside sd adapter in pc: Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 6 FAILPERMISSION DENY (NOT_FIND_SMART_IO) FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO)) finished. total time: 0.000s htc_fastboot finished Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Operation finished Thanks Last edited by 69eyes; 12-20-2019 at 21:38. | |
12-20-2019, 22:00 | #13 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Edit: write security done! write cid 11111111 done! But, unlock bootloader Error! Starting bootloader unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Waiting for the server to process request, it may take up to 5 minutes... Your request was processed successfully! Unlock token has been obtained Sending flash unlocktoken "C:\Program Files (x86)\XTC 2 Tool\\unlocktoken_HT5BGYJ00491.bin" sending 'unlocktoken' (0 KB) ... OKAY writing 'unlocktoken'... (bootloader) flash unlocktoken (bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp (bootloader) [KillSwitch] Last Byte is 0X01, enable unlock (bootloader) Device is unlocked OKAY finished. total time: 1.014s htc_fastboot finished Error: The unlock token was not accepted by the phone. Try to re-calculate it again. |
