Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 04-03-2017, 18:31   #31 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Originally Posted by savanaunlok View Post
I hope you are not trying to tell us that you are an alien from the moon?
In fact ... just in case you have damaged your XTC2Clip ( like me own a few months ago ) ... hosd_signed.img exist in RUU.zip or just firmware.zip ... simple -> extract it. In any case XTC2Clip solution will work, EVEN without the Clip itself...
Old 04-15-2017, 17:17   #32 (permalink)
Member: 2698409
Thanks Meter: 244
Hi,
I have tried every single HOSD file from the support, but when I run fastboot command it says: FAILED (remote: image verify failed. cannot flash this partition)
HTC One M9 (UHL)
S-On
LOCKED
No OS
No Download Mode
No Recovery Mode
Only Bootloader mode. Please advise
The Following 2 Users Say Thank You to oscar.freire For This Useful Post:
Old 04-17-2017, 00:37   #33 (permalink)
Gsm Benghazi's Avatar
Member: 412609
Sonork: 100.1586824
Thanks Meter: 148
m9u
this solution not work me all files tested
any other solution xtc-2-clip team
No OS
No Download Mode
No Recovery Mode
best regards
The Following User Says Thank You to Gsm Benghazi For This Useful Post:
Old 04-17-2017, 12:23   #34 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
As we have already explained, if after flashing all flash hosd files your phone doesn't go to download mode, it's a known emmc problem on M9.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 04-27-2017, 15:33   #35 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 71
could you upload hosd for m9 uhl 7.0 nougat firmware?
thanks
The Following User Says Thank You to ViperGSM For This Useful Post:
Old 04-27-2017, 15:39   #36 (permalink)
Member: 2416253
Thanks Meter: 4,162
thanks
Yes, I already did today.
Old 04-27-2017, 15:47   #37 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 71
any chance for 4.14.401.7 uhl hosd?
attached ones are not working
Old 04-27-2017, 16:20   #38 (permalink)
Member: 2416253
Thanks Meter: 4,162
They are NOT version dependent. As you understand, hosd works even if system is fully erased.
What do you mean by not working? Not flashing (signature error) or not booting after flash?
Old 04-27-2017, 16:35   #39 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 71
flashing went fine but phone still can't enter download mode, it keeps restarting htc logo when i select download from bootloader menu. probably faulty emmc then...
Old 04-27-2017, 16:54   #40 (permalink)
Member: 2416253
Thanks Meter: 4,162
EMMC problem is confirmed with M9, but it's strange to have same problem with HTC 10.
Unfortunately it's very hard to make predictions without having this phone on hands.
Old 04-28-2017, 17:10   #41 (permalink)
ceza031's Avatar
Member: 1724862
Thanks Meter: 448
hosd files not download server please check server
Old 04-28-2017, 20:00   #42 (permalink)
Member: 2416253
Thanks Meter: 4,162
If you have a problem - please be so kind to provide a description or error message.
HOSD download is working fine.
Old 04-29-2017, 16:00   #43 (permalink)
Member: 2325968
Thanks Meter: 5
Htc m9 stuck on bootloader
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version:0.5
(bootloader) variant:MTP eMMC
(bootloader) secure:yes
(bootloader) version-baseband:
(bootloader) version-bootloader:
(bootloader) max-download-size: 0x20000000
(bootloader) partition-type:cache:ext4
(bootloader) partition-size:cache: 0x14000000
(bootloader) partition-type:userdata:ext4
(bootloader) partition-size:userdata: 0x5e0000000
(bootloader) partition-type:system:ext4
(bootloader) partition-size:system: 0x118000000
(bootloader) serialno:FA54LYJ01624
all:
Execution time is 140(ms)
Reading secure flag information
... (bootloader) read secure flag: 3
OKAY
Execution time is 18(ms)
Reading CID information
... FAILunknown command
FAILED (remote: unknown command)
Execution time is 9(ms)
Reading MEID information
Read information failed
The Following User Says Thank You to Javaina For This Useful Post:
Old 04-30-2017, 13:42   #44 (permalink)
Member: 2416253
Thanks Meter: 4,162
Javaina, what's the purpose of your post? Please read this manual from the first post and try our solution.
Old 06-26-2017, 13:04   #45 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
HTC M9U
[code]Reading information...
(bootloader) serialno:FA622YJ00564
all:
Execution time is 156(ms)
OKAY
Execution time is 31(ms)
Execution time is 15(ms)
Read information failed[\code]
after flash hosd file same no download
C:\Program Files\Minimal ADB and Fastboot>fastboot flash hosd m60_hosd_signed_uh
l.img
target reported max download size of 536870912 bytes
sending 'hosd' (22228 KB)...
OKAY [ 0.656s]
writing 'hosd'...
OKAY [ 0.484s]
finished. total time: 1.141s
Page generated in 0.23057 seconds with 9 queries
