09-08-2018, 17:06 | #17 (permalink) |
Banned Join Date: Mar 2011
Member: 1539068 Status: Offline Thanks Meter: 74 | need help for HTC M9u.. Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: 357226065332942 (bootloader) version-main: 3.35.161.12 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U11440792_96.00.51201G_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: xPJ@100 (bootloader) cid: 11111111 all: Execution time is 17(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 1(s) Reading MEID information ... (bootloader) meid: OKAY Execution time is 23(ms) Reading IMEI1 information ... (bootloader) imei: 357226065****** OKAY Execution time is 42(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 24(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 27(ms) Reading serial number information ... (bootloader) Device Serial No. is FA54DYJ09769 OKAY Execution time is 16(ms) Read information completed. |
09-08-2018, 17:15 | #18 (permalink) |
Member: 1539068 Status: Offline Thanks Meter: 74 | Starting flash process... target reported max download size of 800000000 bytes sending 'zip' (49946 KB)... OKAY [ 3.865s] writing 'zip'... (bootloader) HOSD CL#671447 (bootloader) ERR Model ID not matched (bootloader) ERR [SD_UPDATE_ERR] MODEL ID NOT ALLOWED (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 10 (bootloader) ERR Update zip file failed. (bootloader) ERR ZIP ERROR, exit read zip loop (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 10 (bootloader) end@Done FAILED (remote: 10 RU_MODELID_FAIL modelid in android-info mismatched ) finished. total time: 6.264s Flash process completed. Flash not successfull, reboot will not be done Starting flash process... target rom version: 3.35.206.13 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (159355 KB)... OKAY [ 10.070s] writing 'zip'... (bootloader) HOSD CL#671447 (bootloader) ERR Model ID not matched (bootloader) ERR [SD_UPDATE_ERR] MODEL ID NOT ALLOWED (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 10 (bootloader) ERR Update zip file failed. (bootloader) ERR ZIP ERROR, exit read zip loop (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 10 (bootloader) end@Done FAILED (remote: 10 RU_MODELID_FAIL modelid in android-info mismatched ) finished. total time: 12.759s Flash process completed. Flash not successfull, reboot will not be done |
09-09-2018, 08:21 | #19 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
