10-20-2019, 15:38 | #1 (permalink) |
Junior Member Join Date: Oct 2019 Location: Indonesia
Member: 2931704 Status: Offline Thanks Meter: 1 | Power Adapter not found Special recovery file is available Flashing special recovery ... please wait a moment Special recovery was flashed successfully 1. Checking phone connectivity....... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... XTC 2 Power adapter not found. Please connect it to USB port Request completed power adapter usb on PC not hub Driver install im ready change 3 cables flex please help. thanks |
10-21-2019, 02:11 | #2 (permalink) |
Member: 2931704 Status: Offline Thanks Meter: 1 | When the power adapter to the PC beeps and it means it is connected to my PC. However, when used in xtc2clip v1.39 the power adapter tool is not found. Win 10 64bit. A few days ago using a power adapter was still normal. After restarting the PC, uninstalled and reinstalled the power adapter driver, XTC client 1.4 was all normal. Already uninstalled and reinstalled xtc tool 1.39 and all normal but still power adapter not found in xtc2 tool 1.39 Already replace 3 flex cables and replace 4 micro usb cable to power adapter. Please help. Tia |
10-21-2019, 14:12 | #4 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello sir! The flex cable make no sense in this case, as PC uses USB connection via regular microUSB cable. Can you please run device manager and confirm that you see a new USB device whenever you attach (connect) PowerAdapter to your PC? If so, would you mind telling me the name of the device which appears? |
10-21-2019, 17:32 | #5 (permalink) | |
Member: 2931704 Status: Offline Thanks Meter: 1 | Quote:
10-23-2019, 14:34 | #6 (permalink) |
Member: 2931704 Status: Offline Thanks Meter: 1 | I have been using the information on the power adapter not found for three days. on the device manager PC, the power adapter is detected properly. but when I change imei in the power adapter tools the power adapter information is not found. On October 20 2019 my Powewr adapter was normal and smooth. there was no procedure error that I did. Can the power adapter be flashed again? or the slot in xtc2clip does not detect the power adapter? If xtc2clip doesn't detect the power adapter, why is my xtc2clip normal when I insert a smart card? Do I need to PM my serial number xtc2clip? |
10-23-2019, 16:50 | #7 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello! PowerAdapter can't be flashed, and if it's detected in Device Manager it should work fine. XTC2Clip connection to PowerAdapter is not checked during the initial procedure of IMEI repair, in case of misconnection you'll get an error on the phone itself, not in XTC 2 Tool. Do you have a second PC where you can try it, just in case? Thanks. |
10-24-2019, 02:11 | #8 (permalink) | |
If so I will check it. Later in the evening I will flash full wipe 3.35.400.1 from you and try to change IMEI again. I will report the results, hopefully the problem is solved | |
