10-10-2015, 17:33 | #16 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1991420 Status: Offline Thanks Meter: 1 | |
10-12-2015, 16:38 | #22 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | yes i used sprint method m7 Trying to connect in Sprint mode... Trying to connect on COM968 Checking server connection... Communicating with the XTC 2 Clip ... Please check your phone screen: DM Command Service Should appear Choose '1. DM ON' and press SELECT You will be asked to enter MSL code Enter SPC code from last step We will try to do it automatically, but if something will go wrong - please enter manually. At the end you should see 'Diag enabled' or 'Have enabled before' Please wait... Connecting to the server... Please wait, generating unlock hash... Process finished SUCCESSFULLY Please restart your phone for the changes to take effect If you see 'Diag enabled' - please press to Step 4. Otherwise try to perform operation manually. Phone DISconnected |
10-12-2015, 17:22 | #23 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
10-12-2015, 22:03 | #24 (permalink) | |
Crazy Poster Join Date: Nov 2008
Member: 900802 Status: Offline Thanks Meter: 156 | solution m7 sprint Quote:
solution HTC M7 SPRINT UNLOCK (only work with S-OFF) 1) go to the tab "SD mode editor" enable new sec (Security S-OFF). 2) click save to driver. 3) disable S-ON with cable Y and XTC2CLIP 4) once deactivated S-ON go to the tab "SPRINT" 5) Please connect phone in FASTBOOT (vol_down + pwr) 6) click GET SPC Code 7) when you have the SPC click OS 8) enable mode adb 9) go dial write ##3424#, select DM ON 10) click refresh, select port diag 11) click unlock 12) restart the phone | |
10-14-2015, 15:20 | #28 (permalink) |
Freak Poster Join Date: Dec 2001 Location: InnovateK
Member: 8012 Status: Offline Thanks Meter: 124 | M8_WHL .... always server connection failed Starting SPC request Detected MEID: 99000499xxx000 Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Please wait, contacting Sprint database... Server connection failed |
