07-05-2016, 19:13 | #31 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
07-07-2016, 23:08 | #32 (permalink) |
Major Poster Join Date: Dec 2015
Member: 2499126 Status: Offline Thanks Meter: 8 | @xtc2clip : why get we no answer from you because your announcement: "- Restore "Software status: Modified" to "Software status: Official" for HTC 10 family" Where and what should we do for >>>SOFTWARE SATUS: OFFICIAL<<< ??? 3rd attempt - Please give an answer - regards |
07-08-2016, 10:39 | #33 (permalink) | |
Do S-OFF even if the phone is S-OFF. | |
07-09-2016, 09:25 | #35 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Open you own thread and explain the Error, and read Sticky thread instead of place useless post: http://forum.gsmhosting.com/vbb/f961...a-key-2096863/ Br |
07-13-2016, 06:50 | #37 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2592998 Status: Offline Thanks Meter: 6 | So is the bootloader unlock for the verizon htc 10 next up on the list of updates ? As was posted by Dottat the verizon htc 10 is locked down as the oem unlock bootloader setting was removed at verizons request so we cannot unlock the verizon htc 10's until the bootloader unlock is added in an update. We cannot unlock the bootloader through htc dev because verizon has a blank up their blank and will not allow htc dev to unlock our bootloader on the verizon version, where all other USA cellular providers allow htc dev to unlock their bootloaders verizon does not. Verizon is the largest cellular provider in the USA so there are a lot of customers in the USA with verizon htc 10's that need to be bootloader unlocked. |
The Following User Says Thank You to Roefastford For This Useful Post: |
07-14-2016, 04:15 | #38 (permalink) | |
Freak Poster Join Date: Jul 2015
Member: 2424855 Status: Offline Thanks Meter: 17 | Quote:
07-14-2016, 09:10 | #39 (permalink) | |
Junior Member Join Date: Jul 2015
Member: 2420279 Status: Offline Thanks Meter: 22 | Quote:
In order to set S-OFF on the HTC 10 with the CLIP, you MUST first unlock the bootloader, in order to install TWRP. With Verizon, this is NOT possible. Hopefully the people at XTC2CLIP will find another way to get actual HTC keys, which actually bypasses the security, without having to use htcdev.com. This is what we were able to do with previous phones, when the clip had actual HTC keys ( somehow... ) Keep working at it guys, maybe someday you'll find a way to acquire real keys again. That's what everyone with a clip hopes for. It would be nice if you found a way to revert between the old keys, and new keys, and have a method to go back & forth, since the HTC keys have changed with the release of the 10, and the keys are not interchangeable between old and new phones. | |
The Following 3 Users Say Thank You to Zanziman For This Useful Post: |
07-14-2016, 13:10 | #40 (permalink) |
Freak Poster Join Date: Mar 2010 Location: UK
Member: 1255356 Status: Offline Sonork: 100.1607364 Thanks Meter: 129 | Starting bootloader unlock procedure Phone detected, reading token... Token detected successfully Sending flash unlocktoken "C:\Program Files\XTC 2 Tool\\unlocktoken_FA657BN03862.bin" sending 'unlocktoken' (0 KB)... OKAY writing 'unlocktoken'... (bootloader) flash unlocktoken (bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp (bootloader) [KillSwitch] Last Byte is 0X01, enable unlock FAILUnlockToken Verify Fail!! FAILED (remote: UnlockToken Verify Fail!!) Execution time is 1(s) Error: The unlock token was not accepted by the phone. Try to re-calculate it again. |
07-15-2016, 01:44 | #41 (permalink) | |
Member: 2592998 Status: Offline Thanks Meter: 6 | Quote:
We need the bootloader unlocked with root then the xtc2clip will s-off it. The other versions of the htc 10 all have the bootloader unlock feature supported its only the verizon htc 10 that does not. This is a big deal here in the USA because Verizon is the largest cellular provider with the most subscribers so yes the most htc 10's here in the USA are the Verizon version. All other htc 10 versions here are supported just not the most used version here the Verizon one... | |
09-02-2016, 09:11 | #43 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | |
