09-28-2015, 12:12 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Aser z200 pin lock fail Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found [ USB Port:COM31 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. uploading boot image to RAM... Handshake Received from Phone. Detected eMMC FlashType. eMMC cid: 7001004D4D43303447 CHIP : MT65720000 CPU ID: EMMC ID : 7001004D4D43303447 EMMC Size : 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Kingston_KE4CN2L2HA8A2A Read Hardware Information is done. Formatting ... Formating done Action completed Time taken : 00:00:05 Reconnect Battery/USB Cable CS-Tool Ver 1.33 |
09-28-2015, 12:27 | #2 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Quote:
Pls Use Reset File System Option To Remove Pin Lock !!! About Fix Dl Image This Option Soon Add, Now Use Factory Flash File And Tick On Dl IMAGE Checksum, Br., Puneet5154 | |
09-28-2015, 12:34 | #3 (permalink) | |
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
Action : Reset FileSystem Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found [ USB Port:COM31 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. uploading boot image to RAM... Handshake Received from Phone. Detected eMMC FlashType. eMMC cid: 7001004D4D43303447 CHIP : MT65720000 CPU ID: EMMC ID : 7001004D4D43303447 EMMC Size : 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Kingston_KE4CN2L2HA8A2A Read Hardware Information is done. resetting file system ... Error: ResetFS [0x4A] Action completed Time taken : 00:00:06 Reconnect Battery/USB Cable CS-Tool Ver 1.33 | |
09-28-2015, 15:26 | #4 (permalink) | |
Code: About Fix Dl Image This Option Soon Add, Now Use Factory Flash File And Tick On Dl IMAGE Checksum, | |
09-29-2015, 05:41 | #7 (permalink) |
No Life Poster Join Date: Jun 2015 Location: Hongkong
Member: 2409100 Status: Offline Sonork: 100.1667267 Thanks Meter: 3,757 | download New Version 1.34 Added Safe Software Option Safe format is best is Best Option for Format : it will not Affect Bootimg Such DL Image Failed . If Safe format not Solved your Problem, Untick Safe format, its a Ful lFormat DL Tool Image Fix will be added in nearest version |
09-29-2015, 05:57 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hehe, "Safe Format" = Recovery comand line in misc? Did you read a pretty message, when copy that? |
09-29-2015, 06:50 | #9 (permalink) | |
