01-22-2019, 03:22 | #1 (permalink) |
Freak Poster Join Date: Jun 2015
Member: 2405718 Status: Offline Thanks Meter: 14 | Cannot Read Lock pattern on Xiaomi Used S-Module under Xiaomi tab - Read lock pattern Log below for Reset All Settings (FRP) Code: Action : Wipe All Brand: Xiaomi Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery [Preloader Mode] 2.power off Phone, Remove & Reinsert Battery , insert USB Cable [Preloader Mode] (In Case Some Phone Required to hold bootkey) [BROM Mode] Waiting for Phone Usb (Press "F2" to activate fast scan mode)... HID: USB\VID_0E8D&PID_2000&REV_0100 FNM: MediaTek PreLoader USB VCOM (Android) (COM9) Phone found [ USB Port:COM9 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA01 CPU_ID: 0279[MT6797] BV: 02 SecConf: 00000001 Action completed Time taken : 00:00:03 Reconnect Battery/USB Cable CS-Tool Ver 1.38.2 What is the problem? Thanks |
01-25-2019, 01:25 | #3 (permalink) |
Member: 2405718 Status: Offline Thanks Meter: 14 | DONE!! Ticked Encrypted UserData. Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM9 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA01 CPU_ID: 0279[MT6797] BV: 02 SecConf: 00000001 uploading boot image to RAM... Handshake received from Phone. Getting connection agent status:preloader Send boot2 ... Receive SYNC signal, Boot2 runs normally. Getting RAM info ... SRAM: type[0x2] base_address[0x200000] size[0x40000] DRAM: type[0x1] base_address[0x40000000] size[0xC0000000] Getting H/W info ... CHIP : MT6797 CPU ID : EMMC ID : 450100444634303634019FCBDCB25427 EMMC Size: 64GB, usable capacity: 58.25GB EMMC Name: eMMC_Sandisk_DF4064 Resetting ... Resetting done. Action completed Time taken : 00:00:07 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
