05-22-2017, 10:05 | #4966 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Tanzania
Member: 2697846 Status: Offline Thanks Meter: 77 | TECNO-W3 Read Info & FRP Removed Successfully By CS-Tool Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6580 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 700100454838434538 CHIP : MT65800000 CPU ID : EMMC ID : 700100454838434538 EMMC Size: 8GB, usable capacity: 7.13GB EMMC Name: eMMC_Kingston_EH8CE8 Boot Information completed. Reading Project Property ... Brand : TECNO Phone Model : TECNO-W3 Android Ver : 6.0 CPU/Processor : MT6580 MTK Project ver: W3-H806A1-M-161122V94 SW Version : W3-H806A1-M-161122V94 Action completed Time taken : 00:00:15 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6580 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 700100454838434538 CHIP : MT65800000 CPU ID : EMMC ID : 700100454838434538 EMMC Size: 8GB, usable capacity: 7.13GB EMMC Name: eMMC_Kingston_EH8CE8 Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:19 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
The Following User Says Thank You to SkyCleaner For This Useful Post: |
05-22-2017, 10:09 | #4967 (permalink) |
Member: 2697846 Status: Offline Thanks Meter: 77 | Halotel H8401 Readed Info & Pattern Lock Successfully By CS-Tool Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 110100303034474530 CHIP : MT65720000 CPU ID : EMMC ID : 110100303034474530 EMMC Size: 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Toshiba_004GE0 Boot Information completed. Reading Project Property ... Brand : Halotel Phone Model : Halotel H8401 Android Ver : 4.4.2 CPU/Processor : MT6572 MTK Project ver: Halotel_H8401_Ver08_20150629_1720 SW Version : Halotel_H8401_Ver08_20150629_1720 Action completed Time taken : 00:00:14 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 Action : Read Pattern Lock In FlashMode Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 110100303034474530 CHIP : MT65720000 CPU ID : EMMC ID : 110100303034474530 EMMC Size: 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Toshiba_004GE0 Read Hardware Information is done. Reading Pattern code ... Data found. checking ... 1 2 3 4 5 6 7 8 9 Code= 12569 Lock create date: 5/3/2017 2:11:36 AM Action completed Time taken : 00:00:16 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
05-22-2017, 10:11 | #4968 (permalink) |
Member: 2697846 Status: Offline Thanks Meter: 77 | TECNO-Y6 Readed Info & Repaired IMEI Successfully Done By CS-Tool Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483847316505 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483847316505 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Hynix_H8G1e Boot Information completed. Reading Project Property ... Brand : TECNO Phone Model : TECNO-Y6 Android Ver : 4.4.2 CPU/Processor : MT6572 MTK Project ver: Y6-G320-A1-KK-20151020 SW Version : Y6-G320-A1-KK-20151020 Action completed Time taken : 00:00:14 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 Action : Android Repair IMEI(DownloadBoot + META mode) Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483847316505 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483847316505 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Hynix_H8G1e Read Hardware Information is done. Checking imei ... new imei1: 3556*********** new imei2: 3556*********** Repairing Imei... Verify Required... Warning!!! Disconnect USB Cable From Phone. Reconnect Again USB Cable. Waiting for Phone Usb... scanning the mtk usb device...... Phone found Connecting... Posting ... Imei Check.. All Done. Action completed Time taken : 00:00:02 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
05-22-2017, 10:14 | #4969 (permalink) |
Member: 2697846 Status: Offline Thanks Meter: 77 | TECNO-N2 Readed Info & FRP Removed Successfully By CS-Tool Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6580 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 700100563130303038 CHIP : MT65800000 CPU ID : EMMC ID : 700100563130303038 EMMC Size: 8GB, usable capacity: 7.05GB EMMC Name: eMMC_Kingston_V10008 Boot Information completed. Reading Project Property ... Brand : TECNO Phone Model : TECNO-N2 Android Ver : 6.0 CPU/Processor : MT6580 MTK Project ver: alps-mp-m0.mp1-V2.34_rgk6580.we.m SW Version : N2-D2030-A1-M-TZ-Tigo-LOCK-20160601 Action completed Time taken : 00:00:16 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6580 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 700100563130303038 CHIP : MT65800000 CPU ID : EMMC ID : 700100563130303038 EMMC Size: 8GB, usable capacity: 7.05GB EMMC Name: eMMC_Kingston_V10008 Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:26 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
05-22-2017, 10:20 | #4970 (permalink) |
Member: 2697846 Status: Offline Thanks Meter: 77 | Tecno C9 FRP Successfully Removed By CS-Tool Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 0337 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A484147326505 CHIP : MT6753 CPU ID : EMMC ID : 90014A484147326505 EMMC Size: 16GB, usable capacity: 14.69GB EMMC Name: eMMC_Hynix_HAG2e Boot Information completed. Reading Project Property ... Brand : TECNO Phone Model : TECNO-C9 Android Ver : 6.0 CPU/Processor : MT6735 MTK Project ver: C9-H535B1-M-160722V28 SW Version : C9-H535B1-M-160722V28 Action completed Time taken : 00:00:18 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 0337 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A484147326505 CHIP : MT6753 CPU ID : EMMC ID : 90014A484147326505 EMMC Size: 16GB, usable capacity: 14.69GB EMMC Name: eMMC_Hynix_HAG2e Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:27 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
05-22-2017, 10:23 | #4971 (permalink) |
Member: 2697846 Status: Offline Thanks Meter: 77 | Halotel H8401 User Pattern Lock Read Successfully by CS-Tool Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 110100303034474530 CHIP : MT65720000 CPU ID : EMMC ID : 110100303034474530 EMMC Size: 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Toshiba_004GE0 Boot Information completed. Reading Project Property ... Brand : Halotel Phone Model : Halotel H8401 Android Ver : 4.4.2 CPU/Processor : MT6572 MTK Project ver: Halotel_H8401_Ver08_20150629_1720 SW Version : Halotel_H8401_Ver08_20150629_1720 Action completed Time taken : 00:00:14 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 Action : Read Pattern Lock In FlashMode Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 110100303034474530 CHIP : MT65720000 CPU ID : EMMC ID : 110100303034474530 EMMC Size: 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Toshiba_004GE0 Read Hardware Information is done. Reading Pattern code ... Data found. checking ... 1 2 3 4 5 6 7 8 9 Code= 14789 Lock create date: 12/7/2016 11:06:09 PM Action completed Time taken : 00:00:16 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
05-22-2017, 10:25 | #4972 (permalink) |
Member: 2697846 Status: Offline Thanks Meter: 77 | itel it1404 Pattern Lock Read Successfully By CS-Tool Action : Read Info Boot : SC7715-EMMC Warning: if any interrupt during this operation, the phone maybe cant boot because it will always set in download mode, just run "Read info" to reset it Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM6) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... 1st boot done. Sending 2nd boot... 2nd boot done. Checking H/W report info... Waiting for boot patch ack... Done, neo is online, everything under control now ! CHIP : SC7715 CPU ID : 7715A000 EMMC ID : 700100533130303034 EMMC Size: 4GB, usable capacity: 4.00GB EMMC Name: eMMC_Kingston_S10004 Boot Information completed. Reading Project Property ... Brand : itel Phone Model : itel it1404 Android Ver : 4.4.2 CPU/Processor : SP7715EA_V1.0.0 SPD Project ver : scx15_w400_it1404_UUI-user 4.4.2 MocorDroid _P14.30.2_P2 release-keys SW Version : IT1404-W400-20150521 Action completed Time taken : 00:00:21 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 Action : Read Pattern Lock Boot : SC7715-EMMC Warning: if any interrupt during this operation, the phone maybe cant boot because it will always set in download mode, just run "Read info" to reset it Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM6) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... 1st boot done. Sending 2nd boot... 2nd boot done. Checking H/W report info... Waiting for boot patch ack... Done, neo is online, everything under control now ! CHIP : SC7715 CPU ID : 7715A000 EMMC ID : 700100533130303034 EMMC Size: 4GB, usable capacity: 4.00GB EMMC Name: eMMC_Kingston_S10004 Boot Information completed. Reading Pattern code ... Data found. checking ... 1 2 3 4 5 6 7 8 9 Code= 3568 Lock create date: 1/1/2015 12:56:06 PM Action completed Time taken : 00:00:23 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
05-23-2017, 12:24 | #4973 (permalink) |
No Life Poster Join Date: Jan 2017 Age: 40
Member: 2678137 Status: Offline Thanks Meter: 133 | Symphony_H58 MT6580_Emmc Firmware Read Done By CS-Tool Code: Action : Read Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM13 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6580 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 110100303038473330 CHIP : MT65800000 CPU ID : EMMC ID : 110100303038473330 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Toshiba_008G30 Read Hardware Information is done. Reading Project Property ... done. Making dir: C:\Users\DALIM\Documents\MT6580_Symphony_H58_Android5.1_H58_XXX_V5_20170523_112351\...[ok] Reading preloader ......ok New EMI config is detected, auto added it to User Database, cnt=2 Saved to: C:\Program Files\CS-Tool\CST_MainSoftware\private\db\emi\ Reading nvram ......ok Reading lk ......ok Reading boot ......ok Reading recovery ......ok Reading logo ......ok Reading secro ......ok Reading system ......ok Reading cache ......ok Reading userdata ......ok All done. Files saved to: C:\Users\DALIM\Documents\MT6580_Symphony_H58_Android5.1_H58_XXX_V5_20170523_112351\ Action completed Time taken : 00:08:40 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
05-24-2017, 14:00 | #4974 (permalink) |
Freak Poster Join Date: Feb 2017
Member: 2685845 Status: Offline Thanks Meter: 77 | Huwaİ y600 u20 read falsh ok Action : Read Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM11 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3,65GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Reading Project Property ... done. Making dir: C:\Users\a\Desktop\MT6572_HUAWEI Y600-U20_Android4.2.2_Y600-U20V100R001C559B004_20170524_142810\...[ok] Reading preloader ......ok Reading mbr ......ok Reading ebr1 ......ok Reading nvram ......ok Reading uboot ......ok Reading bootimg ......ok Reading recovery ......ok Reading sec_ro ......ok Reading logo ......ok Reading android ......ok Reading cache ......ok Reading usrdata ......ok Reading fat ......ok All done. Files saved to: C:\Users\a\Desktop\MT6572_HUAWEI Y600-U20_Android4.2.2_Y600-U20V100R001C559B004_20170524_142810\ Action completed Time taken : 00:03:59 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
05-25-2017, 09:14 | #4975 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Remove privacy lock Action : Reset Privacy Lock Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM156 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 0321 CPU_SW: 0000 CPU_HW: CA00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100513832334D42 CHIP : MT6735 CPU ID : EMMC ID : 150100513832334D42 EMMC Size: 16GB, usable capacity: 14.57GB EMMC Name: eMMC_Samsung_Q823MB Read Hardware Information is done. Removing privacy lock ... Done. Action completed Time taken : 00:00:20 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
05-28-2017, 10:43 | #4976 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Read Pattern!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Action : Read Pattern Lock In FlashMode Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6582 CPU_SW: 0001 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100513832334D42 CHIP : MT65820000 CPU ID : EMMC ID : 150100513832334D42 EMMC Size: 16GB, usable capacity: 14.57GB EMMC Name: eMMC_Samsung_Q823MB Read Hardware Information is done. Reading Pattern code ... Data found. checking ... 1 2 3 4 5 6 7 8 9 Code= 8639 Lock create date: 24-May-17 12:27:06 AM Action completed Time taken : 00:00:13 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
06-02-2017, 10:55 | #4977 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Austria
Member: 1050590 Status: Offline Thanks Meter: 148 | LENOVO_A6000_MSM8916_ReadFlash_OK Action : Read Flash Tipsower off Phone, Remove & Reinsert Battery, hold vol+ & vol- keys, insert USB Cable Waiting for Phone Usb... Phone found [ USB Port:COM8 ] Connecting... Reading cpu info...ok MSM ID: 0x007050E1 Serial: 0x099C4CB5 Processor: MSM8916, Snapdragon410 Sending the boot...ok Receive ACK, Boot runs normally. Config parameters has been completed. Reading Partitions info...ok Reading storage info...ok eMMC Size: 8GB, usable capacity: 7,28GB Reading Project Property ... Making dir: E:\CS_Qualcomm\MSM8916_Lenovo A6000_Android4.4.4_Kraft-A6000_S033_150402_20170602_113524\...[ok] Dumping Flash Image Now... Reading modem...ok Reading sbl1...ok Reading aboot...ok Reading rpm...ok Reading tz...ok Reading hyp...ok Reading splash...ok Reading fsg...ok Reading sec...ok Reading boot...ok Reading system...ok Reading persist...ok Reading cache...ok Reading recovery...ok Reading userdata...ok Backuping GPT...ok All done. Files saved to: E:\CS_Qualcomm\MSM8916_Lenovo A6000_Android4.4.4_Kraft-A6000_S033_150402_20170602_113524\ Action completed Time taken : 00:13:09 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
06-09-2017, 12:40 | #4978 (permalink) |
Freak Poster Join Date: Oct 2010 Location: in barcelona
Member: 1423754 Status: Offline Sonork: nighthing Thanks Meter: 23 | Xiaomi Redmi Note 3 hello every one can some one tell me how to remove screen password for Xiaomi Redmi Note 3 with cs tool |
The Following User Says Thank You to nighthing For This Useful Post: |
06-13-2017, 16:16 | #4979 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | HTC DESIRE 820G+ CLONE MT6572 HANG ON LOGO DONE BY CS-TOOL Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM148 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 1501004E35585A4D42 CHIP : MT65720000 CPU ID : EMMC ID : 1501004E35585A4D42 EMMC Size: 4GB, usable capacity: 3,65GB EMMC Name: eMMC_Samsung_N5XZMB Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Downloading preloader ......ok Updating rom info ......ok Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Updating rom info ......ok All done. Action completed Time taken : 00:04:49 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
06-16-2017, 13:16 | #4980 (permalink) |
No Life Poster Join Date: Mar 2004 Location: esenler sevgiiletişim TR Age: 58
Member: 60560 Status: Offline Sonork: 100.89085 Thanks Meter: 134 | Asus Zenfone 3 Max ASUS_X008D write imei DONE Action : Android Repair IMEI(META Mode) Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Warning !!! Imei changing is Illegal. Use this function to Restore Orginal Imei we are not responsible for illegal Act Waiting for Phone Usb... scanning the mtk usb device...... Phone found [ USB Port:COM134 ] Connecting... CPU: MT6737 Switching to Meta Mode... Waiting for mete ack... Done, reading... old IMEI: 3519290xxxxxxxxx old IMEI: 3519290xxxxxxxxx Repairing IMEI1=3561520xxxxxxxx Repairing IMEI2=3561520xxxxxxxx checking, pls wait ... [Restart the Phone To Verify New imei ] Action completed Time taken : 00:00:59 Reconnect Battery/USB Cable CS-Tool Ver 1.57.1 |
