07-15-2015, 18:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: cameroon
Member: 260658 Status: Offline Thanks Meter: 184 | Plaese Help Me Here [ solved ] CSTOOL ver1.24 Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... Action : Reset Patten Lock Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... i have drivers intalled also have boot cable please can you help me? |
07-16-2015, 04:47 | #2 (permalink) |
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 46
Member: 716581 Status: Offline Thanks Meter: 767 | @ moment For mtk work with adb mode for reset pattern lock. you need check adb driver. Wait for next version working in boot mode. For spd i'm not sure maybe not working now for some cpu type. |
07-16-2015, 07:53 | #6 (permalink) | |
No Life Poster Join Date: Jun 2015 Location: Hongkong
Member: 2409100 Status: Offline Sonork: 100.1667267 Thanks Meter: 3,757 | Quote:
Remove battery From phone Insert battery again Open CSTool , go to SPD tab > Select boot > Press info hole Volume down & insert battery ( install Drivers) device manager must be detect " SCI USB2Serial ' If you still have problem contact me on Skype For example here : | |
The Following User Says Thank You to CS-Tool For This Useful Post: |
07-16-2015, 08:15 | #7 (permalink) | |
Member: 260658 Status: Offline Thanks Meter: 184 | Quote:
Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... Phone found [ USB Port:COM85 ] Connecting... Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Done. Switching Baudrate to 115200 Sending 2nd Boot... 2nd Boot done. Waiting for Boot init... Done. SC Boot Ver : 8810 SC Boot Mode : 8810004000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC8810 CPU ID: 88100040 NAND ID : 002C00BCFFFFFFFF NAND Size : 512MB NAND Name: NAND_MT29F4G08ABC_2 Boot Information completed. All done. Action completed Time taken : 00:00:05 Reconnect Battery/USB Cable CS-Tool Ver 1.24 Action : Reset Patten Lock Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... Phone found [ USB Port:COM30 ] Connecting... Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Done. Switching Baudrate to 115200 Sending 2nd Boot... 2nd Boot done. Waiting for Boot init... Done. SC Boot Ver : 8810 SC Boot Mode : 8810004000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC8810 CPU ID: 88100040 NAND ID : 002C00BCFFFFFFFF NAND Size : 512MB NAND Name: NAND_MT29F4G08ABC_2 Boot Information completed. Reading Locks Location.. Reseting Locks..... Reset done [ insert simcard & enter any keys ] Action completed Time taken : 00:03:55 Reconnect Battery/USB Cable CS-Tool Ver 1.24 | |
The Following User Says Thank You to nyakam For This Useful Post: |
07-16-2015, 08:21 | #8 (permalink) | |
post your successfully in Sticky thread or saperate thread ., | |
07-18-2015, 21:00 | #9 (permalink) | |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Quote:
Sent from my HTC Desire 601 using Tapatalk | |
