07-15-2015, 07:08 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan Age: 41
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Qmobile a110 flashing probilem Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found [ USB Port:COM83 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. uploading boot image to RAM... Handshake Received from Phone. Error: 0xef [ReadInfo]. analyzing bin file... Error: 0xe14 [wrong file]. Action completed Time taken : 00:00:39 Reconnect Battery/USB Cable CS-Tool Ver 1.24 |
07-15-2015, 07:11 | #2 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found [ USB Port:COM83 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. uploading boot image to RAM... Handshake Received from Phone. Error: 0xef [ReadInfo]. analyzing bin file... Error: 0xe14 [wrong file]. Action completed Time taken : 00:00:39 Reconnect Battery/USB Cable CS-Tool Ver 1.24 |
07-15-2015, 07:12 | #3 (permalink) |
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found [ USB Port:COM83 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. uploading boot image to RAM... Handshake Received from Phone. Error: 0xef [ReadInfo]. analyzing bin file... Analyse Error, invalid or unknow file format Action completed Time taken : 00:01:05 Reconnect Battery/USB Cable CS-Tool Ver 1.24 |
07-15-2015, 07:19 | #4 (permalink) |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found [ USB Port:COM83 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. uploading boot image to RAM... Handshake Received from Phone. Error: 0xef [ReadInfo]. ( i think problem is here ) analyzing bin file... Analyse Error, invalid or unknow file format Action completed Time taken : 00:01:05 Reconnect Battery/USB Cable CS-Tool Ver 1.24 |
07-15-2015, 07:19 | #5 (permalink) | |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Quote:
If Bin Then Its Not Supported With cs , If Factory Then do Full Erase And Re Flash If You have Sure About Rom And Set model is Same . | |
07-15-2015, 08:30 | #12 (permalink) |
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | see this Action : Read Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found [ USB Port:COM83 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. uploading boot image to RAM... Handshake Received from Phone. Error: 0xef [ReadInfo]. Dummping Flash Image Now... Action completed Time taken : 00:00:40 Reconnect Battery/USB Cable CS-Tool Ver 1.24 |
07-15-2015, 09:04 | #14 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Quote:
try other fone readflash my test is this chip here Code: eMMC cid: 45010053454D303447 Read Hardware Information is done. CHIP : MT65720000 CPU ID: EMMC ID : 45010053454D303447 EMMC Size : 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Sandisk_SD7DP24F_4G Dummping Flash Image Now... | |
