08-05-2015, 15:30 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Samsung Copy SM-N9006 pattern read Code: Action : Read Pattern Lock In FlashMode Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found [ USB Port:COM5 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. uploading boot image to RAM... Handshake Received from Phone. Detected eMMC FlashType. eMMC cid: 45010053454D303447 CHIP : MT65720000 CPU ID: EMMC ID : 45010053454D303447 EMMC Size : 4GB, usable capacity: 3.69GB EMMC Name: eMMC_Sandisk_SD7DP24F_4G Read Hardware Information is done. Reading Pattern code ... Data found. checking ... 1 2 3 4 5 6 7 8 9 Code= 159637 Lock create date: 8/4/2015 9:52:26 PM Action completed Time taken : 00:00:17 Reconnect Battery/USB Cable CS-Tool Ver 1.28 |
The Following User Says Thank You to asad_nomy7 For This Useful Post: |
