Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 06-03-2020, 13:18   #16 (permalink)
Member: 2902804
Sonork: 100.1660513
Thanks Meter: 928
amazing
Updated IMEI Repair Function
- Enable Diag first to use this function
- After Diag enabled, Scan and select Diag Port
Old 06-03-2020, 14:17   #17 (permalink)
Member: 2711874
Sonork: 100.650600
Thanks Meter: 462
Nice update umt team thanks
Old 06-03-2020, 14:29   #18 (permalink)
Registered User
Member: 2608490
Thanks Meter: 921
Originally Posted by Abul Basher View Post
api-ms-win-crt-private-l1-1-0.dll error help me
No such error found successfully Installed on Windows 7.Working Fine
Remove/uninstall Old iNstaller and Install Latest 5.5.Hope problem will be solved
Old 06-03-2020, 14:41   #19 (permalink)
Member: 2951726
Sonork: 12345678
Thanks Meter: 3
Good update
Good update! Thanks Big! Umt always helps in work!
Old 06-03-2020, 15:07   #20 (permalink)
souravhasan's Avatar
Member: 431935
Thanks Meter: 59
oppo a3s unlock possibl,,, any one post successfully resul....
The Following User Says Thank You to souravhasan For This Useful Post:
Old 06-03-2020, 16:33   #21 (permalink)
Member: 2944398
Thanks Meter: 9
Nice Update Sir keep it up
Old 06-03-2020, 17:00   #22 (permalink)
Member: 2814900
Thanks Meter: 15
oppo adb driver need
Old 06-03-2020, 18:01   #23 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Originally Posted by abuhasham View Post
Sir pls how to enable ADB ON LOCK DEVICES (OPPO)
Read carefully, it is about privacy lock. On such phone you should be able to enable ADB.
Br,
UMT
The Following 2 Users Say Thank You to U.M.T For This Useful Post:
Old 06-03-2020, 18:09   #24 (permalink)
nduka's Avatar
Member: 1943439
Sonork: 100.1669578
Thanks Meter: 214
Br,
UMT
the question is;
How or any way to enable ADB on the lock devices?
if possible make video on how to do that so users can follow
because if no way of enable adb on privacy devices then no way of working on update
The Following User Says Thank You to nduka For This Useful Post:
Old 06-04-2020, 03:48   #25 (permalink)
bijoychowdry's Avatar
Member: 1984655
Sonork: 119.30.39.25
Thanks Meter: 81
Br,
UMT
the question is;
Old 06-04-2020, 04:16   #26 (permalink)
amrMHF's Avatar
Member: 710690
Thanks Meter: 907
thanks UMT team, good update
Old 06-04-2020, 04:30   #27 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
Originally Posted by nduka View Post
the question is;
agree bro we r almost trust to videos not at feature
Old 06-04-2020, 05:04   #28 (permalink)
Member: 2565591
Sonork: 100.28977
Thanks Meter: 2
great team hard work thnx again. need more updates for oppo brand
Old 06-04-2020, 05:33   #29 (permalink)
Unlockinfo's Avatar
Member: 1785930
Sonork: 100.1685640
Thanks Meter: 4,780
the question is;
i think you dont understand,If the oppo phone has a privacy lock, such as ( Contact,File Manager,Massege,whatsapp,etc)You can do this by turning on adb
go to setting usb debugging on and click dissable lock
Br,
Unlockinfo
The Following 4 Users Say Thank You to Unlockinfo For This Useful Post:
Old 06-04-2020, 07:04   #30 (permalink)
ahmer5050's Avatar
Member: 2385819
Thanks Meter: 827
Very good update.. Keep it up...
Page generated in 0.21808 seconds with 8 queries
