[09-04-21] UMTv2/UMTPro - UltimateMTK v4.1 - Oppo, Realme, Nokia NB0 Extracter & more UMTv2 / UMT Pro UltimateMTK v4.1 http://ultimatemultitool.com//tmp//mtk41.png Supported functions: - Read Info - Reset FRP (For devices supporting this feature) - Reset Locks (All Android Versions, Encrypted Userdata NOT Supported) - Read Pattern (Android 5.x and earlier, Encrypted Userdata NOT Supported) - Format FS - Format FS (Advance) - IMEI Repair in META / Boot Mode - Backup NVRAM - Restore NVRAM - Reboot to META / FACTORY / FASTBOOT Mode - Added Support for Helio CPU (MT6750, MT6755, MT6763, MT6739 etc) - Disable Lock / Restore Lock for Encrypted Userdata - Remove Locks for Encrypted Userdata for Vivo - Factory Reset in META Mode (Vivo, Oppo and others) - SafeFormat Option to let device format itself safely in recovery - Added Support for Helio X20 (MT6797) - Oppo/Realme Safe Factory Reset in META Mode - Added Disable Auth to disable SLA/DAA - Added Mi Account Reset - Xiaomi IMEI Repair - NVRAM/NVDATA Format - META Reboot for SLA Enabled Devices Added: Gionee - F205 iTel - A62 Oppo - A12 (CPH2083) - Narzo 20 Pro (RMX2161) - R15 (PACM00) - Realme 3i (RMX1827) - Realme 7 (RMX2151) - Realme 7 (RMX2163) - Reno2Z (CPH1951) Tecno - Spark Go 2020 (KE5) Updated META (New) IMEI Repair Method - There should not be "Failed to locate" error anymore - If Xiaomi Method does not work, use this method instead Updated Oppo Reset in META Mode - Now device creating ETS/ELT port should work fine Added Nokia (nb0) Firmware extraction - Only Generic Factory Firmware is supported Added Format NVDATA on NVRAM Restore Special thanks to: - neyaz007 - nksonu_jobner Important - Features introduced may work on other devices too, which are not listed here. - User needs to untick By Model checkbox to be able to select Platform manually. - For manual work, just select Platform and DA. - For new secured devices, use Disable Auth, and select Preloader. - Rest operations will work same. Note : Some features are device/OS specific and may not work on all devices. WARNING : ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI. ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS. WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE. Download using Support Access or Mirrors Official Website |
nice update umt team please add option read firmware too |
Please add bootloader Unlock for xiaomi mtk |
Please team. Add reading firmware... Add unlock bootloader... Add bypass antirelock... |
Great Update UMT Team |
Good Update for MediaTek Devices Carry on We are hopeful for more good news thnx Team |
plz ad vivo fastboot to edl |
Nice update umt team Sent from my CPH1727 using Tapatalk |
Oppo A12 Nt LOCK unlock BUT still lock Operation : Oppo Unlock Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM6 Port Name: MediaTek USB Port_V1632 (COM6) Path: \\?\usb#vid_0e8d&pid_0003#5&143fc924&0&9#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM6) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Manufacturer : OPPO Build Flavor : full_oppo6765_19451-user Build Desc. : full_oppo6765_19451-user 9 PPR1.180610.011 eng.root.20210118.235914 release-keys Android Ver. : 9 Patch Level : 2021-01-05 Platform : MT6765 Board : oppo6765_19451 Platform : mt6765 Userdata is NOT ENCRYPTED Unlocking Simlock... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.1] |
oppo f9 cph1881 extracted firmware downgrade done. CPU : MT6771 Storage : EMMC Scatter : C:\Users\Salina\Desktop\Oppo F9 CPH1881\Extracted\MT6771_Android_scatter.txt DA Version : MTK_AllInOne_DA_v3.3001.2019-12-31.22:58 Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM9 Port Name: MediaTek USB Port_V1633 (COM9) Path: \\?\usb#vid_0e8d&pid_0003#5&29057cd7&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0788, [MT6771] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone now... Port : MediaTek USB Port_V1633 (COM9) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... [0] WRITE TO PARTITION [ preloader ] Flashing Bootloader... [3] WRITE TO PARTITION [ recovery ] Flashing Firmware... [22] WRITE TO PARTITION [ md1img ] [23] WRITE TO PARTITION [ spmfw ] [24] WRITE TO PARTITION [ scp1 ] [25] WRITE TO PARTITION [ scp2 ] [26] WRITE TO PARTITION [ sspm_1 ] [27] WRITE TO PARTITION [ sspm_2 ] [28] WRITE TO PARTITION [ cam_vpu1 ] [29] WRITE TO PARTITION [ cam_vpu2 ] [30] WRITE TO PARTITION [ cam_vpu3 ] [34] WRITE TO PARTITION [ lk ] [35] WRITE TO PARTITION [ lk2 ] [36] WRITE TO PARTITION [ boot ] [37] WRITE TO PARTITION [ logo ] [38] WRITE TO PARTITION [ odmdtbo ] [39] WRITE TO PARTITION [ tee1 ] [40] WRITE TO PARTITION [ tee2 ] [41] WRITE TO PARTITION [ odm ] write signature file. [ C:\Users\Salina\Desktop\Oppo F9 CPH1881\Extracted\vendor.sig ] [42] WRITE TO PARTITION [ vendor ] write signature file. [ C:\Users\Salina\Desktop\Oppo F9 CPH1881\Extracted\system.sig ] [43] WRITE TO PARTITION [ system ] [44] WRITE TO PARTITION [ cache ] write signature file. [ C:\Users\Salina\Desktop\Oppo F9 CPH1881\Extracted\userdata.sig ] [45] WRITE TO PARTITION [ userdata ] Flashing Done. Disconnect cable and Power ON phone. |
:eek:good update......:eek: |
Good Update |
Great work team but plzz add MT6779V Helio P95 (12 nm & MT6853 Dimensity 800U 5G (7 nm) thnxxx... |
Br, UMT |
Btw, this is beta and may not work, but some user reported working on some phone. This is the reason we never mentioned it. Br, UMT |
