11-14-2020, 18:51 | #50 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: IN THE KERNEL
Member: 2545468 Status: Offline Thanks Meter: 234 | brother, Quote:
Qualcomm Snapdragon 720G Qualcomm Snapdragon 720G model CPU 2x Kryo 360 2.3 GHz + 6x Kryo 360 1.7 GHz 2x Kryo 360 2.3 GHz + 6x Kryo 360 1.7 GHz Octa-Core Octa-Core Type Fabrication 8 nm 8 nm | |
The Following 4 Users Say Thank You to jrbravo For This Useful Post: |
11-14-2020, 20:45 | #51 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Costa Rica
Member: 1790061 Status: Offline Thanks Meter: 63 | Device : Xiaomi Redmi Note 9S Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM13) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1901400 [SM6250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6250]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTRDNzM0MjQxNDE0MTVBNDM1ODVBNTI0RTUxND Y3OTZCNjc3MDM2NDQ0MTY3NEI3NjMzNDM0Qzc5Mzg3MTU5NDg3 Nz== Requesting UMT Server for Auth Data...NOT_ENOUGH_CREDIT Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.3 |
11-15-2020, 10:07 | #55 (permalink) |
Insane Poster Join Date: Jan 2018 Location: Dar es salaam, Tanzania
Member: 2804958 Status: Offline Thanks Meter: 79 | Device : Xiaomi Redmi Note 9S Operation : Bootloader Unlock/Relock Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM54) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1901400 [SM6250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6250]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTRDNzM0MjQxNDE0NDU5NTc1QTYyNkUzOTc2Mz Y2QzUxNDI0RjM1NzY1MDRCMzA1Mzc0NjczNjQxNjY0MTRDNzI2 Nz== User declined using UMT Server. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.3 I HAVE CREDIT BUT I CAN'T REMOVE MI ACCOUNT ON REDMI NOTE 9S |
11-15-2020, 10:11 | #56 (permalink) |
Member: 2804958 Status: Offline Thanks Meter: 79 | Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM54) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1901400 [SM6250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6250]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTRDNzM0MjQxNDE0NDU5NTc1QTYyNkU3NzY2Mz k2RDRFNzE0MzYzMzYzOTZCMzY3NDQ4Mzc0MTQ5NzQzODQ1NTM1 MT== Requesting UMT Server for Auth Data...Find Device is ON! Please make sure Find Device is OFF then try again. Detecting Chip Type...Failed Auth Enabled Device! You need Mi Auth Account to service! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.3 |
11-15-2020, 10:16 | #57 (permalink) |
Member: 2804958 Status: Offline Thanks Meter: 79 | ...Find Device is ON! Please make sure Find Device is OFF then try again HOW CAN I TURN OFF FIND DIVICE WHILE A PHONE LOCKED BY MI ACCOUNT? FIX THIS UMT TEAM PLS! |
11-15-2020, 12:20 | #58 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | cant do redmi note7 alwes need auth Quote:
11-15-2020, 17:07 | #59 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | it doesn't need auth,all you have to do is to discharge the phone by removing the battery cable(ribbon)and press the power button for 10 to 20 seconds then try again Code: Operation : Wipe EFS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM65) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 7 [lavender] Brand : xiaomi Prod.Name : lavender Software : PKQ1.180904.001, V10.3.5.0.PFGMIXM [Wed Apr 24 13:00:55 WIB 2019] Android Ver. : 9 Patch Level : 2019-04-05 Saving EFS Backup.......OK EFS Backup : EFS_Xiaomi_Redmi Note 7_PKQ1.180904.001_2019-04-05_201115_160151.ueb Reset EFS (Full)......Done Operation Finished. QcFire Ver. 6.3 |
The Following 3 Users Say Thank You to bk.gsm For This Useful Post: |
