05-12-2019, 12:39 | #79 (permalink) |
No Life Poster Join Date: Oct 2006 Location: RAJASTHAN JAIPUR Age: 45
Member: 379001 Status: Offline Sonork: 100.1606686 Thanks Meter: 494 | v7+ data save pattern unlock done by great umt Operation : Reset Locks (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM8) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1716 [msm8953] Software : OPM1.171019.026 release-keys, eng.compil.20190318.212607 [Mon Mar 18 21:26:07 CST 2019] Android Ver. : 8.1.0 Patch Level : 2019-03-01 USERDATA : Encrypted Reading Extended Information...OK Model : vivo 1716 Product : PD1708F_EX Cust. Name : PD1708F_EX-IN Version : PD1708F_EX_A_3.9.1 Resetting Locks (Vivo)...Done Please wait for phone to reboot. Operation Finished. QcFire Ver. 4.1 |
05-12-2019, 12:59 | #81 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
All box and dongle must be with credits and renew, only in this way somebody END of killed marketing getting out work for very Chip price. Must remain in the market only "PROFESSIONAL TECHNICIAN" | |
The Following 4 Users Say Thank You to allumts For This Useful Post: |
05-12-2019, 15:08 | #82 (permalink) | |
Insane Poster Join Date: Feb 2016 Location: Honduras Age: 28
Member: 2529300 Status: Offline Thanks Meter: 37 | Quote:
everyones here knows how UMT QcFire Name their readed firmware files, always end up in error log says read firmware ok Code: Operation : Read Firmware Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000400 OPK_DATA : D64F31F1F574B2C3A0A679CA104A03C0F20B4833F5E2F96A2B56AA09B374C8A6 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8909_044]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK USERDATA : Normal Reading Device Information...OK Device : ZTE Z835 [msm8909] Software : Z835V1.0.0B13, 20170702.034315 [2017年 07月 02日 星期日 03:43:10 CST] Android Ver. : 7.1.1 Patch Level : 2017-07-01 Reading [sbl1]...Done Reading [rpm]...Done Reading [tz]...Done Reading [sec]...Done Reading [splash]...Done Reading [aboot]...Done Reading [modem]...Done Reading [boot]...Done Reading [recovery]...Done Reading [misc]...Done Reading [persist]...Done Reading [cache]...Done Reading [system]...Done Reading [gpt_main0]...Done Reading [gpt_back0]...Done Saved to : C:\UMTool\QcFire\Read\ZTE_Z835_Z835V1.0.0B13_2017-07-01\ Operation Finished. QcFire Ver. 4.1 Just check out file sizes Normal read firmware NCKDongle (Example: Same ZTE Maven 3): just check out file sizes when trying to write back firmware, Qcfire or NCKDongle backup it presents this error: Code: Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000400 OPK_DATA : D64F31F1F574B2C3A0A679CA104A03C0F20B4833F5E2F96A2B56AA09B374C8A6 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8909_044]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Writing [sbl1.mbn] -> [sbl1] ...Done Writing [ddr.img] -> [DDR] ...Failed Operation Finished. QcFire Ver. 4.1 this errors is not only tied to ZTE maven 3, also it happens with others File sizes comparison QcFire Firmware copy vs NCK Dongle Firmware copy: as we can see, copys made with QcFire are somehow incomplete, firmware is around 1.36GB, but NCK Dongle has dumped firmware okay with a size of 3.06 GB, Read/Write error in EDL exploits with QcFire as a result. also using QcFire firmware copy, noticed that QcFire can't write system partition, it only skips and reboot device. BTW, FORMAT CHIP OPTION IS NOT WORKING, ALSO IT DOESN'T SAVE LOGS, JUST IS THERE LIKE A BUTTON WITH NO FUNCTION, THIS IS A THING THAT ON YOUR OWN YOU CAN TEST, HONESTL IT DOESN'T WORK AND OTHER USER CAN CONFIRM THIS IF YOU MAKE A POLL. | |
05-13-2019, 07:07 | #83 (permalink) |
Insane Poster Join Date: Aug 2016 Location: kolkata
Member: 2616576 Status: Offline Sonork: 100.1674982 Thanks Meter: 24 | brother i m agree for activation policy but have one request please add opp new models like oppo A3s, R15,A5,A7,R15x etc etc thanks for supporting... |
05-13-2019, 09:23 | #84 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Here are a few things: - Firmware read by QcFire are encrypted by default, and had smaller size than dump. This option is to save user's HDD space. However this Encrypted Firmware is only supported with QcFire. You can not use this firmware with other tools. - About write error on DDR, you may try to untick this partiton and check flashing. - About error on System flashing, it should not occur with QcFire read firmware. However some issue has been reported with some large sparse system.img flashing. - About Format Chip, for security reason, and to avoid users crying later, we have given 3 questions to go thru. Read it carefully. First you have to say OK, then NO, then again YES. So next time, read carefully, understand and then complaint. If there is a bug, we will fix it as its our work. I think you have got your answer. Br, UMT | |
05-13-2019, 15:49 | #85 (permalink) | |
regards | |
