Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #31 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2011 Age: 56
Member: 1564612 Status: Offline Thanks Meter: 12,145 ![]() | ![]() Quote:
THANKS UMT ![]() JUST SELECT OTHER MODEL WITH UFS 1) Model : Oppo A53 UFS (CPH2127) Operation : Factory Format Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1601300 [SDM460] 00005100 OPK_DATA : 19CF99D55CA3B2E11EA19E52E3541DEDF01898FD9F8C40E625 48F1C7F60ABD47 Initializing Protocol...OK Preparing Loader...Done Sending Loader [CPH2127]...Done Executing Loader...OK Initializing Storage...OK Read : Allowed Write : Protected Alt. Write : Allowed Factory Format Userdata...Done Erasing FRP Data...Done Operation Finished. QcFire Ver. 8.0 ![]() BR Allumts | |
The Following 6 Users Say Thank You to allumts For This Useful Post: |
![]() | #38 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: Inside Technology
Member: 725443 Status: Offline Sonork: 100.1601305 Thanks Meter: 318 | A33 2020 (CPH2137) DONE Model : Oppo A33 (CPH2137) Operation : Factory Format Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1601300 [SDM460] 00005100 OPK_DATA : 19CF99D55CA3B2E11EA19E52E3541DEDF01898FD9F8C40E625 48F1C7F60ABD47 Initializing Protocol...OK Preparing Loader...Done Sending Loader [CPH2137]...Done Executing Loader...OK Initializing Storage...OK Read : Allowed Write : Protected Alt. Write : Allowed Factory Format Userdata...Done Erasing FRP Data...Done Operation Finished. QcFire Ver. 8.0 |
The Following User Says Thank You to mmrozibul For This Useful Post: |
![]() | #40 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 156 | What is this problem Device : Vivo Operation : Reboot EDL (Fastboot) Searching for Device in FastBoot Mode...OK Reading Information...OK FastBoot Ver. : GetVar Variable Not found Product : bengal Bootloader : Locked Version : PD2034F_EX_A_1.9.15 fingerprint.abbr=10/QP1A IMEI : 8675++++++++++++ Rebooting to EDL...UNSUPPORTED FIRWMARE QcFire Ver. 8.0 |
![]() | #41 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Sep 2008 Location: UMT Support section Age: 32
Member: 869809 Status: Offline Thanks Meter: 1,192 | Quote:
Code: Rebooting to EDL...UNSUPPORTED FIRWMARE | |
![]() | #44 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2017
Member: 2792776 Status: Offline Sonork: 1577835 Thanks Meter: 73 | Model : Oppo A53 (CPH2127) Operation : Erase Userdata Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM48) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1601300 [SDM460] 00005100 OPK_DATA : 19CF99D55CA3B2E11EA19E52E3541DEDF01898FD9F8C40E625 48F1C7F60ABD47 Initializing Protocol...OK Preparing Loader...Done Sending Loader [CPH2127]...Done Executing Loader...OK Initializing Storage...OK Read : Allowed Write : Protected Alt. Write : Blocked Erasing Userdata...Failed Erasing FRP Data...Failed Operation Failed. ErrorLog : UEQ5NGJXd2dkbVZ5YzJsdmJqMGlNUzR3SWlCbGJtTnZaR2x1Wn owaVZWUkdMVGdpSUQ4K0NqeGtZWFJoUGdvOGJHOW5JSFpoYkhW bFBTSkZVbEpQVWpvZ1JtRnBiR1ZrSUhSdklISjFiaUIwYUdVZ2 JHRnpkQ0JqYjIxdFlXNWtJQzB4SWlBdlBqd3ZaR0YwWVQ1PV== QcFire Ver. 8.0 Model : Oppo A53 UFS (CPH2127) Operation : Erase Userdata Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM48) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1601300 [SDM460] 00005100 OPK_DATA : 19CF99D55CA3B2E11EA19E52E3541DEDF01898FD9F8C40E625 48F1C7F60ABD47 Initializing Protocol...OK Preparing Loader...Done Sending Loader [CPH2127]...Done Executing Loader...OK Initializing Storage...OK Read : Allowed Write : Protected Alt. Write : Allowed Alt. Write is allowed, using Factory Format Method...Done Erasing FRP Data...Done Operation Finished. QcFire Ver. 8.0 |
The Following User Says Thank You to rashid48581 For This Useful Post: |
![]() | #45 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 172261 Status: Offline Thanks Meter: 294 | Device : Vivo Operation : Reboot EDL (Fastboot) Searching for Device in FastBoot Mode...OK Reading Information...OK FastBoot Ver. : 0.5 Product : unknown command Bootloader : Locked Version QcFire Ver. 8.0 |
