09-23-2018, 05:29 | #16 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,366 | - if you get some issue with phone, which dont work with this update, but were working on 2.6 and earlier versions, please make a detailed thread with proper screenshot and logs. no problem sir work fine Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM8) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] Software : MMB29M, V8.5.2.0.MAMMIED [Thu Aug 24 12:50:40 WIB 2017] Android Ver. : 6.0.1 Patch Level : 2017-07-05 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 2.8 good update sir please add oppo a3s full support sir Last edited by pintu_das; 09-23-2018 at 05:38. |
The Following 2 Users Say Thank You to pintu_das For This Useful Post: |
09-23-2018, 06:34 | #22 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,366 | |
The Following User Says Thank You to pintu_das For This Useful Post: |
09-23-2018, 06:44 | #23 (permalink) |
Freak Poster Join Date: Feb 2010 Location: karachi pakistan
Member: 1237819 Status: Offline Sonork: [email protected] Thanks Meter: 148 | umt teem adedd motorola red firmware |
09-23-2018, 07:05 | #24 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 57
Member: 137980 Status: Offline Thanks Meter: 168 | mi note 5 pro frp mi acc ok Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM40) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 Software : OPM1.171019.011, V9.5.19.0.OEIMIFA [Fri Jul 6 19:09:51 WIB 2018] Android Ver. : 8.1.0 Patch Level : 2018-06-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 2.8 |
The Following 2 Users Say Thank You to nilan For This Useful Post: |
09-23-2018, 07:14 | #25 (permalink) |
Insane Poster Join Date: Dec 2012 Location: Colombia
Member: 1858778 Status: Offline Thanks Meter: 32 | Can I repair the IMEI of these Xiaomi models mentioned? Can Miui be updated without losing the signal? I have tried to repair using qcn hex editing and erase modems, but after update miui loses signal. Can this tool do this without loses of signal? |
The Following User Says Thank You to mekato For This Useful Post: |
09-23-2018, 08:26 | #27 (permalink) |
No Life Poster Join Date: May 2016 Location: Not Found...
Member: 2572504 Status: Offline Sonork: No More Use Thanks Meter: 441 | Always Doing Great Job Keep It Up World's First Solution Always BR Gsm Aakas |
The Following User Says Thank You to 5262gsmaakas For This Useful Post: |
09-23-2018, 09:16 | #29 (permalink) |
Freak Poster Join Date: Dec 2007 Location: bangladesh, chittagong
Member: 648453 Status: Offline Thanks Meter: 82 | redmi note 5 (whyred ) frp done by QcFire Ver. 2.8 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM43) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.3 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 Software : OPM1.171019.011, V9.5.6.0.OEIMIFA [Tue Apr 10 21:39:15 WIB 2018] Android Ver. : 8.1.0 Patch Level : 2018-03-01 Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 2.8 |
The Following 2 Users Say Thank You to sahed07860 For This Useful Post: |
09-23-2018, 09:19 | #30 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Graat team UMT keep it up... Quote:
The Following 5 Users Say Thank You to allumts For This Useful Post: |
