10-01-2018, 21:34 | #76 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2350594 Status: Offline Thanks Meter: 9 | Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM15) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Preparing Loader...Done Sending Loader [Note5Pro]...Done Executing Loader...OK Detecting Chip Type...Failed VIP Enabled / Auth Enabled Device! Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogT25seSBub3Ag YW5kIHNpZyB0YWcgY2FuIGJlIHJlY2V2aWVkIGJlZm9yZSBhdX RoZW50aWNhdGlvbi4iLz4KPC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIC8+CjwvZG F0YT5= Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 2.9 |
10-02-2018, 05:23 | #77 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,447 | Quote:
Who told you to use Test device? | |
10-02-2018, 22:40 | #83 (permalink) |
Insane Poster Join Date: Jul 2014 Location: colombia Age: 46
Member: 2221260 Status: Offline Thanks Meter: 8 | the account gets removed but when i get connected to wifi it gets blocked again Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.3 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 Software : OPM1.171019.011, V10.0.1.0.OEIMIFH [Mon Sep 10 19:57:39 WIB 2018] Android Ver. : 8.1.0 Patch Level : 2018-09-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 2.9 |
10-03-2018, 06:00 | #84 (permalink) |
Junior Member Join Date: Dec 2014 Location: Avengers Mtk UMT Team
Member: 2306060 Status: Offline Sonork: [email protected] Thanks Meter: 8 | oppo a3s pin lock help .................................................. .....meeeee |
10-03-2018, 21:57 | #88 (permalink) |
Freak Poster Join Date: Aug 2009 Location: In Home
Member: 1089778 Status: Offline Thanks Meter: 11 | Device : Xiaomi Redmi Note 5 Pro Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM83) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...Failed VIP Enabled / Auth Enabled Device! Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogT25seSBub3Ag YW5kIHNpZyB0YWcgY2FuIGJlIHJlY2V2aWVkIGJlZm9yZSBhdX RoZW50aWNhdGlvbi4iLz4KPC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIC8+CjwvZG F0YT5= Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 2.9 helppp helpppppp brooo |
10-04-2018, 03:27 | #89 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: hyderabad, india
Member: 1623940 Status: Offline Thanks Meter: 22 | 2.8 use version Quote:
Use 2.8 version tested by me | |
10-04-2018, 04:23 | #90 (permalink) | |
Member: 1089778 Status: Offline Thanks Meter: 11 | error 2.8 error error Quote:
error persists and remains blocked | |
