Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 12-14-2017, 04:58   #196 (permalink)
Member: 879723
Thanks Meter: 6
new nck Pro box setup problem
Old 12-14-2017, 11:29   #197 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Hello.
Loock where you post, here is UMT section!!!!
Old 12-15-2017, 04:15   #198 (permalink)
Member: 2632431
Thanks Meter: 15
Error trying to update
I bought nck+umt dongle, nck updated good, but when i try to use any umt software says that i need to update the card, then i found this.
Card connected, reading info.
Serial: UMT3********
Connecting to server, wait..
[check card]Server buzy, try latter[01]!.
Old 12-15-2017, 09:48   #199 (permalink)
sindhi.aslam's Avatar
Member: 1919988
Thanks Meter: 178
when server will become ok
team plz reply
Old 12-15-2017, 10:27   #200 (permalink)
.:GSM-SRABON:.'s Avatar
Member: 2283947
Sonork: 100:1662279
Thanks Meter: 317
Originally Posted by schizoidcock View Post
i bought nck+umt dongle, nck updated good, but when i try to use any umt software says that i need to update the card, then i found this.
Serial: Umt3********
connecting to server, wait..
[check card]server buzy, try latter[01]!.
team plz reply
server will be back soon try after few hours.
Old 12-16-2017, 08:28   #201 (permalink)
murad6229's Avatar
Member: 987131
Sonork: 100.1614852
Thanks Meter: 25
card firmware is obsolete please
Serial: UMTXXXXXX16
Connecting to server, chhecking for update, wait.
[updatefw]Server buzy, try latter[01]!.
Old 12-16-2017, 23:50   #202 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
umt qcfire v1.3 auto selections of loader has a bug..( exe selecting wrong loader)
but in v1.2 auto selection was correct.. (exe selectin correct loaders.)
plz fix that in next version ok..
Old 12-17-2017, 06:43   #203 (permalink)
Member: 2250656
sir for umt box uart cable schemetic it uegent i m try many times but no responce
Old 12-20-2017, 12:13   #204 (permalink)
Member: 995861
Sonork: 1672589.vicky
Thanks Meter: 9
Serial: UMTxxxxxxxx
update eror plz help
Old 12-20-2017, 16:18   #205 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Can you please show us an example?
Because there is nothing changed in 1.2 and 1.3 for loader selection.
Br,
Ultimate Multi Tool
Old 12-23-2017, 13:27   #206 (permalink)
Member: 2589480
Thanks Meter: 5
Originally Posted by prince2047 View Post
Umt team plz check this
mi phone factory reset problem
Searching for phone in sideload mode...Found
Ext Info
Failed to read information.
Make sure phone is connected in sideload mode.
Operation Failed.
but use down ver module qcfire 1.2 ok work
chane pc your problam was solve
Sent from my Redmi Note 4 using Tapatalk
Old 12-27-2017, 18:37   #207 (permalink)
Sr-Rafique's Avatar
Member: 1606308
Sonork: 100.1604666
Thanks Meter: 187
Originally Posted by .:GSM-SRABON:. View Post
No Results Found
The page you requested could not be found. Try refining your search, or use the navigation above to locate the post.
please help umt teem ...need crad driver v2
Old 12-27-2017, 18:57   #208 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by Sr-Rafique View Post
No Results Found
Read carefully what writed in first post of this thread.
http://forum.gsmhosting.com/vbb/12813132-post1.html
Old 12-28-2017, 13:03   #209 (permalink)
Member: 1909641
Thanks Meter: 20
Port : USB Coonection
Baud Rate : Not Applicable
Device : Motorola
Operation : Enable ADB
Searching for device... Found
Connecting to device... OK
Model : MotoG3-TE
Bootloader : 0x80F2
Baseband : M8936_2020632.44.03.21.57.01R MERLIN_APAC_CUST
Build : Blur_Version.24.241.21.merlin_retasia.retasia.en.0 3
Android : 6.0.1
Enabling ADB... Unsupported Patch Level! Failed
Operation Failed.
Elapsed Time: 00:01
[Module Ver. 4.5]
Log Saved to Logs\171228_172850.log
error in new version pll fix it umt team ..
Old 12-28-2017, 13:05   #210 (permalink)
Member: 1909641
Thanks Meter: 20
new umt tool error in motorola frp reset pll pll fix it
Br,
Ultimate Multi Tool
Device : Motorola
Model : MotoG3-TE
Bootloader : 0x80F2
Android : 6.0.1
Operation Failed.
Elapsed Time: 00:01
[Module Ver. 4.5]
Page generated in 0.19128 seconds with 9 queries
