02-27-2023, 13:06 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Cuba
Member: 346150 Status: Offline Sonork: 100.1661091 Thanks Meter: 429 | 1 - Unlock Bootloader 2 - Format NVRAM - NVDATA option 3 - Check the baseband is OK 4 - Try to format from recovery / or do Format FS from software and see if OK. 5 - Try the Oppo method If not work try downgrade the firmware and repead all operation. If not work restore the security and check the original imei. |
The Following User Says Thank You to windowshu For This Useful Post: |
02-28-2023, 09:12 | #3 (permalink) | |
Freak Poster Join Date: Feb 2017 Location: Pakistan
Member: 2684815 Status: Offline Thanks Meter: 133 | Quote:
Device Bootloop after downgrade Same Issue When we repair it on any old firmware Bootloop | |
02-28-2023, 09:13 | #4 (permalink) | |
02-28-2023, 16:42 | #5 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | First Unlock Bootloader, then flash with CPH2185PU_11_A.17_201228_8cedfeaf and then make sure phones starts fine and baseband OK. After that repeat repair operation. Br, UMT |
