06-08-2022, 17:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: places I repair phones
Member: 621698 Status: Offline Thanks Meter: 405 | alcatel REVVL 4+ ( 5062W / 5062Z ) detected via UMT but not possible to FRP unlock T-mobile U.S / metropcs REVVL 4+ ( 5062W / 5062Z ) I tried to unlock FRP ( just to try via UMT if it will work, even is not on the list ) I see that I can able to connect by doing this procedure: unplug usb cable from computer then full OFF hold VOLUME + & VOLUME - ( while is fully off ) then plug the usb cable once the logo of download mode pop-up, I press and hold the volume + then UMT detect it but since is not supported because no available loader. It wont FRP unlock My question is that can you able to support it? here is my logs: Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM6) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 56004200 OPK_DATA : ECEBE8AD3B2485D5D4244343D6C50BA75621C21BD932473133 788832DD217DA7 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [SDM665]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.6 |
The Following User Says Thank You to mymiela0419 For This Useful Post: |
