10-26-2021, 12:35 | #1 (permalink) |
Freak Poster Join Date: Jun 2013 Location: mexico
Member: 1958094 Status: Offline Thanks Meter: 57 | BUG QcFire V7.3 Xiaomi dead phone Mi 10T Pro (Phone alive, flash for enable dual sim) Dead after flash and lost credits Detect qualcomm 9800 Flash Multiprogram Mode Code: Operation : Multi Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM64) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1300C00 [SD8250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_firehose_lite.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJlIFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbCB2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRhdGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYWxzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ3NTE0MjQxNDE0MzMxNjM3QTQ0NDY1OTc1NkI3OTZENzk1MzRFNTgzOTJENzk2NTcxNDE0QzM0Njc3NzZBNkQ0MU== Requesting UMT Server for Auth Data...OK Credits Left: 10 Authenticating...OK Detecting Chip Type...OK Hardware : SD8250, UFS, 256 GB LU Count : 6 [0x03B52000] [0x00001000] [0x00001000] [0x00002000] [0x00040000] [0x00004000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 4096 Processing [rawprogram0.xml] Writing [dummy.img] -> [switch] ...Done Writing [misc.img] -> [misc] ...Done Writing [logfs_ufs_8mb.bin] -> [logfs] ...Done Writing [metadata.img ] -> [metadata]...Done Writing [super.img ] -> [super]...Done Writing [imagefv.elf] -> [imagefv] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img ] -> [cache]...Done Writing [cust.img ] -> [cust]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram1.xml] Writing [xbl_config.elf] -> [xbl_config] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [gpt_main1.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup1.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram2.xml] Writing [xbl_config.elf] -> [xbl_configbak] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [gpt_main2.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup2.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram3.xml] Writing [gpt_main3.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup3.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram4.xml] Writing [multi_image.mbn] -> [multiimgoem] ...Done Writing [qupv3fw.elf] -> [qupfw] ...Done Writing [qupv3fw.elf] -> [qupfwbak] ...Done Writing [vbmeta.img] -> [vbmeta] ...Done Writing [storsec.mbn] -> [storsec] ...Done Writing [vbmeta_system.img] -> [vbmeta_system] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [aop.mbn] -> [aop] ...Done Writing [aop.mbn] -> [aopbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [km41.mbn] -> [keymaster] ...Done Writing [km41.mbn] -> [keymasterbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [uefi_sec.mbn] -> [uefisecapp] ...Done Writing [uefi_sec.mbn] -> [uefisecappbak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [dtbo.img] -> [dtbo] ...Done Writing [logo.img] -> [logo] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [boot.img] -> [boot] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [gpt_main4.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup4.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram5.xml] Writing [persist.img] -> [persist] ...Done Resetting device...Done Operation Finished. QcFire Ver. 7.3 Single Program Mode Code: Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM64) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1300C00 [SD8250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_firehose_lite.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJlIFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbCB2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRhdGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYWxzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ3NTE0MjQxNDE0MzMxNjM3QTQ0NDYzNzM3Njk0NzUyNDc3NTQ3NjE3NTQ4NzY3NjUwNkM0NjQ0MzY0ODZBNTU2Nz== Requesting UMT Server for Auth Data...OK Credits Left: 5 Authenticating...OK Detecting Chip Type...OK Hardware : SD8250, UFS, 256 GB LU Count : 6 [0x03B52000] [0x00001000] [0x00001000] [0x00002000] [0x00040000] [0x00004000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 4096 Writing [dummy.img] -> [switch] ...Done Writing [misc.img] -> [misc] ...Done Writing [logfs_ufs_8mb.bin] -> [logfs] ...Done Writing [metadata.img ] -> [metadata]...Done Writing [persist.img] -> [persist] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img ] -> [cache]...Done Writing [exaid.img] -> [exaid] ...Done Writing [cust.img ] -> [cust]...Done Writing [super.img ] -> [super]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Reading Partition Table...OK Resetting FRP Lock.......Done Resetting device...Done Operation Finished. QcFire Ver. 7.3 |
10-27-2021, 18:09 | #10 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | True, QcFire is Killer in features and performance, all other credits go to the user, who become almightly and flash anything they want, eve if manufacturer, who in this case is Xiaomi, has forbidden. So, just remember, with great power, comes great responsibility, to choose correct function, correct firmware. Br, |
The Following 3 Users Say Thank You to U.M.T For This Useful Post: |
10-27-2021, 21:42 | #11 (permalink) | |
Member: 1958094 Status: Offline Thanks Meter: 57 | Quote:
It is the best support | |
10-28-2021, 16:12 | #12 (permalink) | |
Problem solved with other tool and enable dual sim Thanks for you support | |
The Following User Says Thank You to zapata13 For This Useful Post: |
