11-22-2020, 19:39 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Germany,Hessen
Member: 8966 Status: Offline Thanks Meter: 31 | hi to all about Redmi Note 8T Disable screenlock then i try it with special tab Disable lock screen then i get this errror i write only system image but after that same error what can i do for fix this problem thanks Operation : Disable Screen Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM189) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SDM665, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 8T [willow] Brand : xiaomi Prod.Name : willow_eea Software : PKQ1.190616.001, V11.0.11.0.PCXEUXM [Wed Aug 19 20:14:27 CST 2020] Android Ver. : 9 Patch Level : 2020-08-01 USERDATA : Encrypted Disabling Screen Locks...Failed If system partition is manipulated, flash only system and try again. Operation Failed. QcFire Ver. 6.3 |
The Following User Says Thank You to HAITEKGSM For This Useful Post: |
07-07-2021, 16:15 | #2 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Crimea
Member: 1797426 Status: Offline Thanks Meter: 289 | Operation : Disable Screen Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM36) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SDM665, EMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 8T [willow] Brand : xiaomi Prod.Name : willow_ru Software : PKQ1.190616.001, V11.0.4.0.PCXRUXM [Fri Jun 12 19:15:17 CST 2020] Android Ver. : 9 Patch Level : 2020-06-01 USERDATA : Encrypted Disabling Screen Locks...Failed If system partition is manipulated, flash only system and try again. Operation Failed. QcFire Ver. 7.0 |
