![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | how to enable daig port asus z010d [Answered] i try to connect but need daig enale any body sare daig enable code or tested root |
![]() | #2 (permalink) | |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | phone root ok but cant enable daig need help here is log Quote:
![]() | #6 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2015 Location: Inside UMT
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,787 | May be you are not aware but It is not a bug with UMT. Android 5.0.2 has this type of issue. So either update to 5.1 or downgrade to 4.x.x Br, Ultimate Multi Tool |
![]() | #7 (permalink) | |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | update 6.01 but cant enable daig any other way plz Quote:
![]() | #8 (permalink) | |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | i see one more pst here and i do this but face this error Quote:
![]() | #9 (permalink) | |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | connect here but cant enable Quote:
The Following User Says Thank You to ranagaurav For This Useful Post: |
![]() | #11 (permalink) | |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | i follow this command but not enable daig Quote:
![]() | #12 (permalink) | |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | after instal busy box show this Quote:
![]() | #13 (permalink) | |
![]() | #14 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2685662 Status: Offline Thanks Meter: 0 | I discovered my problem of IMEI NULL and serial number 111111 .. when I did some cleaned I deleted the FACTORY folder .. I will restore the imei and the serial number ... signal gets over is falling. Need help setting up the FACTORY folder |
