04-08-2021, 18:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | How to reset Nokia 3.4 ta-1283 Operation : Generic Fastboot FRP Reset (2) Searching for Device in FastBoot Mode...OK Reading Information...OK FastBoot Ver. : 0.4 Product : DRS_sprout Bootloader : Locked Removing FRP Lock...Failed Operation Failed. UltimateFRP Ver. 0.5.1 |
04-08-2021, 19:00 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | First find the Nokia NB0 firmware and extract using QcFire. If it goes well, you need to find TP for EDL mode. Then you can try in EDL mode using QcFire. Br, UMT |
The Following 3 Users Say Thank You to U.M.T For This Useful Post: |
07-01-2021, 08:11 | #4 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You can directly use NB0 in QcFire to flash as it can use internal loader automatically. Most probably loader will in database for this model. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
07-01-2021, 09:41 | #7 (permalink) |
Freak Poster Join Date: May 2007 Location: Bulgaria,Sofia
Member: 509103 Status: Offline Thanks Meter: 40 | Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM11) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1601300 [E1601300] 00000000 OPK_DATA : 33C81B0D9C95728D384C524C64A4E5996B51A9D888417B18AB 704ECD276936FF Initializing Protocol...OK Using Auto Loader Selection [0] CPU not found in database. Operation Finished. QcFire Ver. 6.9 |
The Following User Says Thank You to godjy For This Useful Post: |
