![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2012 Location: delhi
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | mi note 5 pro frp solution plz add Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [E1C00C00] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [0] CPU not found in database. Operation Failed. Module Ver. 2.0 |
![]() | #3 (permalink) |
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | already try bt same issue Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8996_016.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.1 |
![]() | #4 (permalink) |
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | its done by manual loder here is logo Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM16) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 Pro [sdm660] Software : NGI77B, V9.2.6.0.NEIMIEK [Thu Mar 15 21:57:01 CST 2018] Android Ver. : 7.1.1 Patch Level : 2018-02-01 Resetting Mi Account Data...Done Preparing Data... |
The Following 2 Users Say Thank You to aryanmobile1989 For This Useful Post: |
![]() | #7 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Aug 2016 Location: kolkata
Member: 2616576 Status: Offline Sonork: 100.1674982 Thanks Meter: 24 | Device : Xiaomi Redmi Note 5 Pro Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM13) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogT25seSBub3Ag YW5kIHNpZyB0YWcgY2FuIGJlIHJlY2V2aWVkIGJlZm9yZSBhdX RoZW50aWNhdGlvbi4iLz4KPC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIC8+CjwvZG F0YT5= Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 2.7.0 |
![]() | #8 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2008
Member: 711273 Status: Offline Thanks Meter: 81 | hi, mi - mei7 Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Reading Auth Blob...OK Getting Auth Data...Auth App Not Running! VIP Enabled / Auth Enabled Device! Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+PGRhdGE+PGxvZyB2YWx1ZT0iRVJST1I6IE9ubHkgbm9wIGFu ZCBzaWcgdGFnIGNhbiBiZSByZWNldmllZCBiZWZvcmUgYXV0aG VudGljYXRpb24uIiAvPjwvZGF0YT48P3htbCB2ZXJzaW9uPSIx LjAiIGVuY29kaW5nPSJVVEYtOCIgPz48ZGF0YT48cmVzcG9uc2 UgdmFsdWU9Ik5BSyIgLz48L2RhdGE+ Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 2.7.0 |
![]() | #9 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 ![]() | Quote:
![]() | #10 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: kolkata
Member: 621454 Status: Offline Thanks Meter: 30 | Short Test point ![]() Download FRP File: Download then Download the crack tool which supports FRP Unlock in Redmi Note 5 pro When script message appear click on Ok Then flash the phone to unlock frp |
The Following User Says Thank You to sunil8888 For This Useful Post: |
