08-28-2021, 17:11 | #1 (permalink) |
Freak Poster Join Date: Jun 2013 Location: surat
Member: 1961657 Status: Offline Sonork: 100.1643528 Thanks Meter: 71 | mi note 7 Diag enabled but Reading Phone Information... Failed Port Closed. Port : COM60 : Qualcomm HS-USB Android DIAG 901D (COM60) Baud Rate : 921600 Device : Qualcomm Android Operation : Read IMEI Opening Port... OK Reading Phone Information... Failed Port Closed. Operation Failed. Elapsed Time: 00:02 [Module Ver. 5.5] Log Saved to Logs\210828_213937.log |
08-28-2021, 18:01 | #2 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 34
Member: 869809 Status: Offline Thanks Meter: 1,711 | Quote:
b.r. | |
The Following 2 Users Say Thank You to bk.gsm For This Useful Post: |
08-30-2021, 16:30 | #5 (permalink) | |
Member: 1961657 Status: Offline Sonork: 100.1643528 Thanks Meter: 71 | Quote:
Ok now what to do after installing the eng firmware now imei showing complete Port : COM60 : Qualcomm HS-USB Android DIAG 901D (COM60) Baud Rate : 921600 Device : Qualcomm Android Operation : Read IMEI Opening Port... OK Reading Phone Information... OK Compile : Jan 3 2019 00:22:00 Release : Nov 06 2018 21:00:00 Hw Ver. : sdm660.g Build : MPSS.AT.3.1-00777-SDM660_GEN_PACK-1.176821.1 IMEI [1] : 864357040338666 IMEI [2] : 864357040828666 Operation Finished. Elapsed Time: 00:03 [Module Ver. 5.5.1] Log Saved to Logs\210830_205917.log Now I can flash back to normal firmware?? | |
08-30-2021, 17:53 | #6 (permalink) | |
b.r. | |
08-31-2021, 11:02 | #8 (permalink) | |
Finally done with little change First flashed with Eng firmware then write ENG QCN then flashed with normal firmware 1 IMEI came but phone complete Thanks bk.gsm for helping and giving your time and knowledge | |
The Following 4 Users Say Thank You to qweaq For This Useful Post: |
