10-20-2021, 17:42 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | poco m3 i connected phone in edl mode via test point but read info not working Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM5) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1D01400 [SDM662] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM662]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SDM662, UFS, 64 GB LU Count : 6 [0x00DD4800] [0x00000800] [0x00000800] [0x00008000] [0x00100000] [0x00008000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...Failed USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 7.3 |
10-20-2021, 17:51 | #2 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
please post more info about your phone condition/status b.r. | |
10-20-2021, 18:02 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | It may be possible due to super partition structure which holds system, vendor and other products. We will add parsing of super more properly in upcoming update. Br, |
The Following User Says Thank You to U.M.T For This Useful Post: |
10-20-2021, 18:02 | #4 (permalink) |
