![]() | #1756 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2013
Member: 1913632 Status: Offline Thanks Meter: 233 | Operation : Format FS Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM15) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009B00 [8976] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8976_1.ufl]... Done Executing Loader... OK Hardware : 8976, eMMC, 32 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : Xiaomi MI MAX [msm8952] Software : MMB29M, V7.5.6.0.MBCMIDE [Fri Jul 15 18:20:27 CST 2016] Android Ver. : 6.0.1 Preparing Data... Done Formatting Userdata... Done Operation Finished. |
The Following User Says Thank You to pravakar333 For This Useful Post: |
![]() | #1757 (permalink) |
Member: 1913632 Status: Offline Thanks Meter: 233 | Xiaomi MI MAX [msm8952] ac reset done Operation : Reset Mi Account Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM15) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone... OK Waiting for response... Ignored Init Handshake Sequence... OK Hardware ID : E1009B00 [8976] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8976_1.ufl]... Done Executing Loader... OK Hardware : 8976, eMMC, 32 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : Xiaomi MI MAX [msm8952] Software : MMB29M, V7.5.6.0.MBCMIDE [Fri Jul 15 18:20:27 CST 2016] Android Ver. : 6.0.1 Reading Data... Done Resetting Mi Account... Done Operation Finished. |
![]() | #1758 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Lyf_ls-5014 frp done Code: Operation : Reset FRP Checking for existing devices... Found Port : COM4 Opening Port... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8909.ufl]... Done Executing Loader... OK Hardware : 8909, eMMC, 8 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : Haier LS-5014 [msm8909] Software : LYF_LS-5014_01_11, eng.quanjia.20160928.140722 [Wed Sep 28 14:10:18 CST 2016] Android Ver. : 5.1.1 Resetting FRP Lock... . . . . . Done Operation Finished. |
The Following User Says Thank You to niloy2007 For This Useful Post: |
![]() | #1759 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 ![]() | moto g3 done Code: Port : USB Coonection Baud Rate : Not Applicable Device : Motorola Operation : Enable ADB Searching for device... Found Connecting to device... OK Model : MotoG3-TE Bootloader : 0x80F0 Baseband : M8936_2020632.44.03.21.57.01R MERLIN_APAC_CUST Build : Blur_Version.24.226.17.merlin_retasia.retasia.en.03 Android : 6.0.1 Enabling ADB... OK Now Turn Off device, and put in Factory Mode again. When phone is completely ON, accept ADB Authrization on phone. Now use Reset FRP button. Operation Finished. Elapsed Time: 00:01 [Module Ver. 3.8] Log Saved to Logs\170706_185545.log Port : ADB Interface Baud Rate : Not Applicable Device : Motorola Operation : Reset FRP Searching for Device... Found Model : MotoG3-TE Version : 6.0.1 Hardware : qcom Baseband : M8936_2020632.44.03.21.57.01R MERLIN_APAC_CUST SIM Card : ABSENT,ABSENT CPU : armeabi-v7a Type : Unknown MEID(1) : Null/Empty Root : Not Rooted Resetting FRP Lock... Done Operation Finished. Elapsed Time: 00:07 [Module Ver. 3.8] Log Saved to Logs\170706_191626.log |
The Following User Says Thank You to rehmani For This Useful Post: |
![]() | #1760 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 ![]() | mi max done Searching for phone in sideload mode... Found Device Id : hydrogen Version : V8.0.1.0.MBCMIDG Code Base : 6.0.1 Ext Info : GB, en, F Formatting Data... Done Rebooting device... Done Operation Finished. Module Ver. 0.9 |
![]() | #1761 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2013 Location: SEGOU MALI
Member: 1862574 Status: Offline Thanks Meter: 69 | power of umt SAM SM A5100 2016 FRP DONE WITH GREAT TOOL Device: Samsung Device Operation: Reset FRP (New Method) Port: COM28 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: MSM8916 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Failed to reset FRP.! Possibly unsupported firmware, flash phone and try agaiin Elapsed Time: 00:23 [Ultimate Samsung Flasher v1.1]THIS IS LOG FILE |
The Following User Says Thank You to tontonbouba For This Useful Post: |
![]() | #1762 (permalink) |
Member: 1862574 Status: Offline Thanks Meter: 69 | Sam grand prime g531h frp bone with umt Device: GT-I8190 Operation: Reset FRP / RL / EE Port: COM16 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Resetting FRP Lock Data... Done Elapsed Time: 00:08 [Ultimate Samsung Flasher v1.1] |
![]() | #1763 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: Tirana Age: 43
Member: 143851 Status: Offline Thanks Meter: 163 | ![]() select frp resr new method go to download mode frp reset done thanks UMT Device: Samsung Device Operation: Reset FRP (New Method) Port: COM25 : SAMSUNG Mobile USB Modem #3 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:14 [Ultimate Samsung Flasher v1.1] |
The Following User Says Thank You to ak0101 For This Useful Post: |
![]() | #1764 (permalink) |
Member: 143851 Status: Offline Thanks Meter: 163 | ![]() Select reset frp old method go to download mode rest frp ok Operation: Reset FRP / RL / EE Port: COM25 : SAMSUNG Mobile USB Modem #3 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: MSM8916 [HiSpeed] Resetting FRP Lock Data... Done Elapsed Time: 00:07 [Ultimate Samsung Flasher v1.1] |
![]() | #1765 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Sm-j200f frp done Code: Device: Samsung Device Operation: Reset FRP (New Method) Port: COM70 : SAMSUNG Mobile USB Modem #5 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-J200F IMEI: 3588*********** Software: J200FXXU3AQC2/J200FOJV3AQC1/J200FXXU3AQC1/J200FXXU3AQC2 Init Download Mode... OK Port: COM10 : SAMSUNG Mobile USB Modem Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 01:02 [Ultimate Samsung Flasher v1.1] |
![]() | #1766 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Sm-j700f frp done***** Code: Device: Samsung Device Operation: Reset FRP (New Method) Port: COM72 : SAMSUNG Mobile USB Modem #7 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-J700F IMEI: 3528************ Software: J700FXXU4BQE3/J700FODD4BQE1/J700FXXU4BQE4/J700FXXU4BQE3 Init Download Mode... OK Port: COM10 : SAMSUNG Mobile USB Modem Reading Data from Phone... Done Chipset: LSI7580 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 01:02 [Ultimate Samsung Flasher v1.1] |
![]() | #1767 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: INDIA
Member: 629327 Status: Offline Sonork: 100.1663374 Thanks Meter: 537 | MI NOTE 4G PRIME FLASHING DONE BY EDL MODE ![]() Sent from my vivo 1603 using Tapatalk |
The Following 2 Users Say Thank You to .:TithiMobile:. For This Useful Post: |
![]() | #1768 (permalink) |
Member: 629327 Status: Offline Sonork: 100.1663374 Thanks Meter: 537 | VIVO Y21L PATTERN LOCK REMOVE DONE ![]() Sent from my vivo 1603 using Tapatalk |
![]() | #1769 (permalink) |
Banned ![]() ![]() ![]() ![]() Join Date: Mar 2017 Location: F.S.D Age: 31
Member: 2691025 Status: Offline Thanks Meter: 234 | motrola XT1080 pinlock removed motrola XT1080 pinlock removed With Umt Multi tool ![]() Br Mirza Asim |
The Following User Says Thank You to Danishmirza For This Useful Post: |
![]() | #1770 (permalink) |
Member: 2691025 Status: Offline Thanks Meter: 234 | Gtabs G100 user lock removed By Umt king Gtabs G100 user lock removed By Umt king ![]() Br MIRZA ASIM |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
