![]() | #691 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 ![]() | Code: Device: GT-I8190 Operation: Flash Firmware Port: COM7 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8810 [HiSpeed] Sending Partition [SBL1]... Done Sending Partition [KERNEL]... Done Sending Partition [RECOVERY]... Done Sending Partition [modem]... Done Sending Partition [CSC]... Done Sending Partition [system]... Done Sending Partition [HIDDEN]... Done Sending Partition [PARAM]... Done Closing Session... Done Operation Finished. Elapsed Time: 07:06 [Ultimate Samsung Flasher v0.9] Port : COM118 : SAMSUNG Mobile USB Modem #23 Baud Rate : 115200 Device : Samsung G361H Operation : Read Info Opening Port... OK Reading Information... OK Model : GT-S7262 IMEI : 35432406942---- Version Info : S7262XXUAND2 : S7262ODDANA1 : S7262XXUAMK2 : S7262XXUAND2 Port Closed. Operation Finished. Elapsed Time: 00:07 [Module Ver. 3.4] Log Saved to Logs\170130_164327.log |
The Following User Says Thank You to rehmani For This Useful Post: |
![]() | #692 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung sm-j320f frp Device: SM-J320F Operation: Apply FRP Patch Port: COM10 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Applying Patch Data... . . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 00:23 [Ultimate Samsung Flasher v0.9] Device: SM-J320F Operation: Reset FRP Searching for Device... Found Model: SM-J320F Baseband: J320FDDU0APK3 Bootloader: J320FXXU0APB1 PDA: J320FDDU0APL1 Android Version: 5.1.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:07 [Ultimate Samsung Flasher v0.9] |
The Following 2 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
![]() | #693 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | Oppo A33w reset pattern done Code: Port : ADB Interface Baud Rate : Not Applicable Device : Oppo A33w Operation : Remove Locks Goto [Emergency Call] and type following Code *#67766776# In Connection Page, click on [ADB OFF] Button Once it is truned ON, Connect USB Cable and Install ADB Drivers. Clearing Screen Locks... Done Operation Finished. Elapsed Time: 00:10 [Module Ver. 3.4] Log Saved to Logs\170130_221307.log |
The Following 2 Users Say Thank You to tsabila For This Useful Post: |
![]() | #694 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 ![]() | samsung i8552 flash done Code: Device: GT-I8190 Operation: Flash Firmware Port: COM11 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: MSM8x25 [HiSpeed] Sending Partition [APPS]... Done Sending Partition [RECOVERY]... Done Sending Partition [SYSTEM]... Done Sending Partition [FAT]... Done Sending Partition [CACHE]... Done Sending Partition [HIDDEN]... Done Closing Session... Done Operation Finished. Elapsed Time: 15:06 [Ultimate Samsung Flasher v0.9] |
![]() | #695 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 ![]() | mi2014818 format done Code: Operation : Format FS Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port Driver Info : Mobile, qcusbser.sys, 2.1.0.3 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1507000 [8916] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Firehose Loader... Done Executing Loader... OK Hardware : 8916, eMMC, 16 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table... OK Preparing Data... Done Formatting Userdata... Done Operation Finished. Remove cable, reconnect battery / hold Power Button ~15 seconds. |
![]() | #696 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 371 | ![]() Code: Samsung J200G FRP Remove Done Code: Device: Samsung Device Operation: Reset FRP (New Method) Port: COM122 : SAMSUNG Mobile USB Modem #31 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-J200G IMEI: 353278083957022 Software: J200GDCU2APL6/J200GODD2APL6/J200GDDU2APJ2/J200GDCU2APL6 Init Download Mode... OK Port: COM52 : SAMSUNG Mobile USB Modem #4 Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:52 [Ultimate Samsung Flasher v0.9] |
The Following User Says Thank You to ishant For This Useful Post: |
![]() | #697 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 ![]() | samsung g531f frp reset,flash done Code: Operation: Reset FRP / RL / EE Port: COM11 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: PXA1L88 [HiSpeed] Resetting FRP Lock Data... Done Elapsed Time: 00:08 [Ultimate Samsung Flasher v0.9] Code: Device: GT-I8190 Operation: Flash Firmware Port: COM11 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: PXA1L88 [HiSpeed] Sending Partition [SYSTEM]... Done Closing Session... Done Operation Finished. Elapsed Time: 04:41 [Ultimate Samsung Flasher v0.9] |
![]() | #698 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2014 Location: kolkata
Member: 2234421 Status: Offline Sonork: 100.1674816 Thanks Meter: 60 | motorola xt1022 hang on logo done Baud Rate : Not Applicable Device : Motorola QC Operation : Flash Fw Model : condor Fw Version : condor_retaildsds-user 4.4.4 KXC21.5-40 46 release-keysMSM8610BP_1034.307.26.02P Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1022 Boot Ver. : 5009 Baseband : Not Found Software : Blur_Version.21.12.40.condor_retaildsds.retaildsds all.en.03 IMEI : 353324060649461 CPU : MSM8210 CS RAM : 1024MB Elpida S4 SDRAM DIE=4Gb EMMC : 4GB Micron REV=06 PRV=12 TYPE=17 Sending Data [partition]... Done Sending Data [motoboot]... Done Sending Data [logo]... Done Sending Data [boot]... Done Sending Data [recovery]... Done Sending Data [system]... Done Sending Data [system]... Done Sending Data [system]... Done Sending Data [modem]... Done Erasing [modemst1]... Done Erasing [modemst2]... Done Sending Data [fsg]... Done Erasing [cache]... Done Erasing [userdata]... Done Operation Finished. Elapsed Time: 02:03 [Module Ver. 3.4] |
The Following User Says Thank You to deb kumar dhali For This Useful Post: |
![]() | #700 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 ![]() | samsung g531h unlock done Code: Port : COM21 : SAMSUNG Mobile USB Modem #3 Baud Rate : 115200 Device : Samsung G361H Operation : Unlock Opening Port... OK Reading Information... OK Model : SM-G531H IMEI : 35295707897---- Version Info : G531HXXU0APE1 : G531HOJV0APE1 : G531HXXU0APE1 : G531HXXU0APE1 Preparing Phone... OK Reading Lock Status... OK Status : SIM Locked* Phone May Be Hard Locked, Unlock May Not Work Reading Lock Levels.. OK Lock Level [0] : Locked Lock Level [1] : Unlocked Lock Level [2] : Unlocked Lock Level [3] : Unlocked Lock Level [4] : Unlocked Resetting Lock Codes... Done UnFreeze : 62124272 Level[1] : 70114050[Locked] Level[2] : 00000000[Unlocked] Level[3] : 00000000[Unlocked] Level[4] : 00000000[Unlocked] Level[5] : 00000000[Unlocked] If phone still locked, tick Reset Code + Froce Mode and Unlock again. Port Closed. Operation Finished. Elapsed Time: 00:14 [Module Ver. 3.4] Log Saved to Logs\170201_132433.log |
![]() | #701 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 ![]() | samsung i8552 format done Code: Port : COM10 : SAMSUNG Mobile USB Modem Baud Rate : 115200 Device : Samsung G361H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : GT-I8552 IMEI : 35984305156---- Version Info : I8552XXANJ1 : I8552ODDANG1 : I8552DDAOC1 : I8552XXANJ1 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:12 [Module Ver. 3.4] Log Saved to Logs\170201_173415.log |
![]() | #702 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | LYF LS-4505 6.0.1 Resetting FRP Lock... . . . Done (QcFire 0.3) Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Firehose Loader... Done Executing Loader... OK Hardware : 8909, eMMC, 8 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : LYF LS-4505 [msm8909] Software : LS-4505-S22A_LYF_L12EN_202_160930, 24decd3 [Fri Sep 30 11:19:34 CST 2016] Android Ver. : 6.0.1 Resetting FRP Lock... . . . Done Remove cable, reconnect battery / hold Power Button ~15 seconds. |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
![]() | #703 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2011 Location: India Age: 34
Member: 1682257 Status: Offline Thanks Meter: 60 | zte 183 unlock done Port : COM32 : Qualcomm HS-USB QDLoader 9008 (COM32) Baud Rate : 921600 Device : ZTE S183 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Nov 27 2013 15:03:05 Release : Apr 24 2009 24:00:00 Hw Ver. : RIC_S183 ESN : 80998269 MEID : A1000049B3E657 Unlocking Security... OK Build : RIC_S183_RBTL21FV1.0.0B07 Soft Ver. : RIC_S183_NL_RBTL21FV1.0.0B09 Detected : S183 User Code : 0000 Checking if Supported for Unlock... OK Setting Download Mode... OK Waiting for Reconnect... OK Initializing Flash Chip... OK Flash Chip : SPANSION S71VS128RC0 Chip Size : 16 MB Unlocking Phone... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:29 Module Ver. [1.6] |
![]() | #704 (permalink) |
Member: 1682257 Status: Offline Thanks Meter: 60 | samsung j200g frp done Device: Samsung Device Operation: Reset FRP (New Method) Port: COM24 : SAMSUNG Mobile USB Modem #3 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:12 [Ultimate Samsung Flasher v0.9] |
![]() | #705 (permalink) |
Member: 1682257 Status: Offline Thanks Meter: 60 | Read Bootloader Unlock Token (Fastboot) motorola xt 1506 Port : Fastboot Mode Baud Rate : Not Applicable Device : Motorola QCOM Operation : Read Bootloader Unlock Token (Fastboot) Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : Not Found Boot Ver. : 5108 Baseband : MSM8610BP_18033.4614.44.00R EMEA_DSDS_CUST Software : Blur_Version.22.56.3.otus_reteu_ds.reteuall.en.EU IMEI : CPU : MSM8212 CS RAM : 1024MB Elpida S4 SDRAM DIE=4Gb EMMC : 8GB Micron REV=06 PRV=12 TYPE=17 Reading Bootloader Unlock Token... Done Visit following URL to get Unlock Code https://goo.gl/lT5opy Token Copied to Clipboard. Operation Finished. Elapsed Time: 00:04 [Module Ver. 3.4] |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
