04-28-2017, 17:48 | #1261 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | SAMSUNG SM-J500F Reset FRP (New Method) U.M.T Operation: Reset FRP (New Method) Port: COM94 : SAMSUNG Mobile USB Modem #24 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-J500F IMEI: 35267207+++++++++= Software: J500FXXU1BQB2/J500FODD1BQA1/J500FDDU1BPK2/J500FXXU1BQB2 Init Download Mode... OK Port: COM4 : SAMSUNG Mobile USB Modem #3 Reading Data from Phone... Done Chipset: MSM8916 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 01:05 [Ultimate Samsung Flasher v1.1] |
The Following 2 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
04-29-2017, 07:26 | #1262 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Lyf ls-4503 $$$ frp Code: Operation : Reset FRP Checking for existing devices... Found Port : COM4 Opening Port... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8909.ufl]... Done Executing Loader... OK Hardware : 8909, eMMC, 8 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : LYF LS-4503 [msm8909] Software : LS-4503-S10A_LYF_L11EN_210_160115, fd9d8f9 [Mon Feb 20 10:03:20 CST 2017] Android Ver. : 5.1.1 Resetting FRP Lock... . . Done Operation Finished. |
The Following User Says Thank You to niloy2007 For This Useful Post: |
04-29-2017, 09:07 | #1263 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Oppo a57 read flash fi.le done Code: Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1B00600 [8940] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8940.ufl]... Done Executing Loader... OK Hardware : 8937, eMMC, 32 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : OPPO CPH1701 [msm8937] Software : CPH1701EX_11_A.11_170421, eng.root.20170421.072824 [Fri Apr 21 07:31:14 CST 2017] Android Ver. : 6.0.1 Reading [modem]... Done Reading [sbl1]... Done Reading [sbl1bak]... Done Reading [rpm]... Done Reading [rpmbak]... Done Reading [tz]... Done Reading [tzbak]... Done Reading [devcfg]... Done Reading [devcfgbak]... Done Reading [dsp]... Done Reading [oppodycnvbk]... Done Reading [oppostanvbk]... Done Reading [LOGO]... Done Reading [sec]... Done Reading [splash]... Done Reading [aboot]... Done Reading [abootbak]... Done Reading [boot]... Done Reading [recovery]... Done Reading [cache]... Done Reading [system]... Done Reading [persist]... Done Reading [misc]... Done Reading [mdtp]... Done Reading [cmnlib]... Done Reading [cmnlibbak]... Done Reading [cmnlib64]... Done Reading [cmnlib64bak]... Done Reading [keymaster]... Done Reading [keymasterbak]... Done Reading [DRIVER]... Done Reading [userdata]... Done Reading [PrimaryGPT]... Done Reading [BackupGPT]... Done Operation Finished. |
The Following 2 Users Say Thank You to niloy2007 For This Useful Post: |
04-29-2017, 09:09 | #1264 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Xiaomi Redmi Note 3 FORMAT HANG LOGO SOLVED UMT Operation : Format FS Checking for existing devices... Found Port : COM21 Opening Port... OK Init Handshake Sequence... OK Hardware ID : E1009B00 [8976] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8976.ufl]... Done Executing Loader... OK Hardware : 8976, eMMC, 16 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : Xiaomi Redmi Note 3 [msm8952] Software : LMY47V, V8.0.6.0.LHOMIDG [Tue Oct 25 19:12:10 CST 2016] Android Ver. : 5.1.1 Preparing Data... Done Formatting Userdata... Done Operation Finished. |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
04-29-2017, 13:14 | #1265 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Samsung j200g frp $. Code: Device: Samsung Device Operation: Reset FRP (New Method) Port: COM54 : SAMSUNG Mobile USB Modem #12 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-J200G IMEI: 359268070824206 Software: J200GDDU2APL7/J200GODD2APL7/J200GDDU2APJ2/J200GDDU2APL7 Init Download Mode... OK Port: COM10 : SAMSUNG Mobile USB Modem Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 01:18 [Ultimate Samsung Flasher v1.1] |
04-29-2017, 14:12 | #1266 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Lyf ls-4505 frp done umt Operation : Reset FRP Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : HS-USB Diagnostics 9008 (COM21) Driver Info : Mobile, qcusbser.sys, 2.1.0.3 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8909.ufl]... Done Executing Loader... OK Hardware : 8909, eMMC, Unknown Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : LYF LS-4505 [msm8909] Software : LS-4505-S16A_LYF_L11EN_201_160228, 83a28cb [Wed Feb 15 11:06:00 CST 2017] Android Ver. : 5.1.1 Resetting FRP Lock... . . Done Operation Finished. |
04-30-2017, 08:13 | #1267 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Xiaomi Redmi Note 3 mi account remove done Operation : Reset Mi Account Checking for existing devices... Found Port : COM21 Opening Port... OK Init Handshake Sequence... OK Hardware ID : E1009B00 [8976] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8976.ufl]... Done Executing Loader... OK Hardware : 8976, eMMC, 32 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : Xiaomi Redmi Note 3 [msm8952] Software : MMB29M, V8.2.2.0.MHOMIDL [Fri Mar 24 15:36:11 CST 2017] Android Ver. : 6.0.1 Reading Data... Done Resetting Mi Account... Done Operation Finished. |
04-30-2017, 13:21 | #1268 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | mi 3s format done umt Searching for phone in sideload mode... Found Device Id : land_global Version : V8.1.1.0.MALMIDI Code Base : 6.0.1 Ext Info : GB, en, F Formatting Data... Done Operation Finished. |
04-30-2017, 14:31 | #1269 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lenovo zuk z1 frp remove done Code: Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Qualcomm FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 0.5 Product : MSM8974 Warranty : Yes Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Done Operation Finished. Elapsed Time: 00:07 [Module Ver. 3.8] Log Saved to Logs\170427_160130.log |
04-30-2017, 14:33 | #1270 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | mts m151 repair security done Code: Port : COM109 : Qualcomm HS-USB Diagnostics 9004 (COM109) Baud Rate : 921600 Device : Lava M141 Operation : Read Info Opening Port... OK Reading Information... OK Compile : Jan 15 2015 21:01:24 Release : Apr 24 2010 23:00:00 Hw Ver. : W027_KK9 ESN : 00000000 MEID : 00000000000000 IMEI : 000000000000000 BUILD : Q1110-W027_KK9A_M151_MTS-3375 Reading Extended Information... OK User Code : 0000 SPC : 000000 Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.5] Log Saved to Logs\170427_152610.log Port : COM109 : Qualcomm HS-USB Diagnostics 9004 (COM109) Baud Rate : 921600 Device : Lava M141 Operation : MEID Repair Opening Port... OK Reading Information... OK Compile : Jan 15 2015 21:01:24 Release : Apr 24 2010 23:00:00 Hw Ver. : W027_KK9 ESN : 00000000 MEID : 00000000000000 IMEI : 000000000000000 BUILD : Q1110-W027_KK9A_M151_MTS-3375 Reading Extended Information... OK User Code : 0000 SPC : 000000 Writing MEID A100004C961---... OK New MEID : A100004C961--- Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.5] Log Saved to Logs\170427_152614.log Port : COM109 : Qualcomm HS-USB Diagnostics 9004 (COM109) Baud Rate : 921600 Device : Lava M141 Operation : Read Info Opening Port... OK Reading Information... OK Compile : Jan 15 2015 21:01:24 Release : Apr 24 2010 23:00:00 Hw Ver. : W027_KK9 ESN : 809233-- MEID : A100004C961--- IMEI : 000000000000000 BUILD : Q1110-W027_KK9A_M151_MTS-3375 Reading Extended Information... OK User Code : 0000 SPC : 000000 Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.5] Log Saved to Logs\170427_152629.log |
04-30-2017, 14:34 | #1271 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lyf ls5009 read rom done Code: Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM42) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.6.7 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8909.ufl]... Done Executing Loader... OK Hardware : 8909, eMMC, 8 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : LYF LS-5009 [msm8909] Software : LS-5009-S11A_LYF_L11EN_209_160115, 7d00459 [Fri Feb 17 11:58:08 CST 2017] Android Ver. : 5.1.1 Reading [modem]... Done Reading [sbl1]... Done Reading [sbl1bak]... Done Reading [aboot]... Done Reading [abootbak]... Done Reading [rpm]... Done Reading [rpmbak]... Done Reading [tz]... Done Reading [tzbak]... Done Reading [misc]... Done Reading [splash]... Done Reading [sec]... Done Reading [boot]... Done Reading [system]... Done Reading [persist]... Done Reading [cache]... Done Reading [recovery]... Done Reading [userdata]... Done Reading [PrimaryGPT]... Done Reading [BackupGPT]... Done Operation Finished. |
The Following User Says Thank You to rehmani For This Useful Post: |
04-30-2017, 14:42 | #1272 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | j500f format done Code: Port : COM95 : SAMSUNG Mobile USB Modem #11 Baud Rate : 115200 Device : Samsung G361H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : SM-J500F IMEI : 35959407351---- Version Info : J500FXXU1APD6 : J500FODD1APD6 : J500FDDU1APE1 : J500FXXU1APD6 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:07 [Module Ver. 3.8] Log Saved to Logs\170426_143451.log |
04-30-2017, 14:48 | #1273 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | olive c2130 unlock done Code: Port : COM82 : Olive CDMA Device HS-USB Diagnostics (COM82) Baud Rate : 921600 Device : Haier OL2130 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Oct 22 2013 14:51:43 Release : Apr 14 2011 21:00:00 Hw Ver. : 6012TT33 ESN : 805300-- MEID : A100002103E--- BUILD : VC2130-3385 Setting Download Mode... OK Reconnecting Phone... OK Preparing Phone.. OK Sending Bootloader... OK Executing Bootloader... OK Syncing Communication... OK Initializing Flash Chip... Flash Chip : INTEL PF38F3050M0Y3DEA Chip Size : 16 MB Preparing Patch Data... OK Patching Firmware... OK Resetting Phone... OK Phone Successfully Unlocked. Port Closed. Operation Finished. Time Taken: 00:21 Module Ver. [1.5] Log Saved to Logs\170425_133016.log |
The Following 2 Users Say Thank You to rehmani For This Useful Post: |
05-01-2017, 07:15 | #1274 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | SAMSUNG SM-J210F Reset FRP (New Method) UMT Device: Samsung Device Operation: Reset FRP (New Method) Port: COM98 : SAMSUNG Mobile USB Modem #25 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-J210F IMEI: 3541750+++++++++ Software: J210FXXU0AQD1/J210FODD0AQD1/J210FXXU0AQD1/J210FXXU0AQD1 Init Download Mode... OK Port: COM4 : SAMSUNG Mobile USB Modem #3 Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:58 [Ultimate Samsung Flasher v1.1] |
05-01-2017, 07:35 | #1275 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Xolo spd frp done Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Huawei SPD FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 1.0 Product Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Done Operation Finished. Elapsed Time: 00:14 [Module Ver. 3.8] Log Saved to Logs\170501_115204.log |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
