02-21-2023, 03:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Brazil
Member: 232960 Status: Offline Thanks Meter: 419 | Nokia 2.4 TA-1274 MTK andorid 12 FRP sucessiful Before removing patern, user code or pin.... cant do nothing and everetimes errors on UMT bootloader blocks all operations on the way, so first remove user code, pattern or pin OK?? this is focus on news Nokias... this is secret to acess userdata i think so... To remove that(hard reset and finish hard protection) i use SP_Flash_Tool_v5.2020_Win that a way to hard reset phone(in ispanish and use goolgle translator case needed) use this metod beside: https://www. clangsm . com /forum/index.php?showtopic=559156(remove spaces and this) After sucess remove user code, patern or pin Just do remove FRP with UMT MTK new v0.2 at first try... Tested TA-1274 Nokia 2.4 Android 12 patch November 2022 Operation : Reset FRP Waiting for Device...Found Port : MediaTek USB Port (COM19) Device Path : \\?\usb#vid_0e8d&pid_0003#5&b65f817&0&4#{86e0d1e0- 8089-11d0-9ce4-08003e301f73} Driver : MediaTek Inc., 3.0.1504.0 [usb2ser.sys] Mode : BROM Hw ID : MT6765 [0766] Helio P35/G35 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:True] [DAA:True] MEID : E343013F894C6CD8699619A0CC308CCC SoC ID[0] : FA5147D6AE285136AF5930F27F2D0B6B SoC ID[1] : 5491BF1990846F6839E7BF12F2458C34 Running Exploit...Done Downloading Preloader...Failed! Dump preloader failed! Need preloader! Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] Using DA : MTK_AllInOne_DA.bin DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 880103534C443634476588A91189A73B [EMMC] Initializing Storage...OK Sending 2nd DA...OK Initialize DA Extension...OK Int. RAM : 0x000000000003A000 [232,00 KB] Ext. RAM : 0x00000000C0000000 [3,00 GB] Flash ID : SLD64G CID : 880103534C443634476588A91189A73B BOOT1 : 0x0000000000400000 [4,00 MB] BOOT2 : 0x0000000000400000 [4,00 MB] RPMB : 0x0000000000400000 [4,00 MB] USERAREA : 0x0000000E67800000 [57,62 GB] Connected to High-Speed DA Port Reading Partition Table...OK Resetting FRP...OK Operation Finished. [UltimateMTK2 v0.2] Log Saved : 20230220_222525.log Last edited by edcentec; 02-21-2023 at 03:35. |
02-22-2023, 20:56 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Sorry but we could not understand what error did you face? Can you please post log here so we can see what actually happened and why you need to use SPFlash Tool? Br, UMT |
