10-03-2022, 08:37 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | please add nova 9 se huawei id remove[Solved] and then restore backup done alive again but not resolved my problem |
10-06-2022, 07:20 | #3 (permalink) |
Member: 653398 Status: Offline Thanks Meter: 669 | Operation : Remove Huawei ID (Automatic Reest) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM19) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1801B00 [SM6225] 6D001500 OPK_DATA : E2D62B196391DF63693F01E753DC831C3A831CF3CA9D702A1C 2EB2F1374208B2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6225]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : SM6225, UFS, 128 GB LU Count : 6 [0x01D7E800] [0x00000800] [0x00000800] [0x00002000] [0x00047000] [0x00002000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...Failed Reading Backup... Backup : Huawei_Id_Backup_SM6225_221006_111658.bak If device stuck in boot loop, restore this backup. Resetting Huawei ID...Done Operation Finished. QcFire Ver. 8.3 Last edited by haroon454; 10-06-2022 at 07:20. Reason: remove done but still lock |
The Following User Says Thank You to haroon454 For This Useful Post: |
