11-03-2016, 06:05 | #1536 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung j110h format done Code: Port : COM108 : SAMSUNG Mobile USB Modem #16 Baud Rate : 115200 Device : Samsung G361H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : SM-J110H IMEI : 353415073353--- Version Info : J110HXXU0AOI7 : J110HODD0AOI4 : J110HDDU0AOH2 : J110HXXU0AOI7 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:08 [Module Ver. 3.1] Log Saved to Logs\161103_103432.log |
The Following User Says Thank You to rehmani For This Useful Post: |
11-03-2016, 12:04 | #1537 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung s7262 format done Code: Port : COM109 : SAMSUNG Mobile USB Modem #18 Baud Rate : 115200 Device : Samsung G360H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : GT-S7262 IMEI : 358913058615--- Version Info : S7262XXUAMI6 : S7262ODDAMI6 : S7262XXUAMI6 : S7262XXUAMI6 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:20 [Module Ver. 3.1] Log Saved to Logs\161103_163336.log |
11-03-2016, 14:44 | #1538 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g355h format done Code: Device: GT-I8190 Operation: Flash Firmware Port: COM69 : SAMSUNG Mobile USB Modem #3 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SC7715 [HiSpeed] Sending Partition [CSC]... Done Sending Partition [HIDDEN]... Done Closing Session... Done Operation Finished. Elapsed Time: 00:35 [Ultimate Samsung Flasher v0.7] |
11-03-2016, 14:55 | #1539 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | SM-J200H FRP Reset Done Code: Device: SM-J200H Operation: Reset FRP Searching for Device... Found Model: SM-J200H Baseband: J200HDDU0APE1 Bootloader: J200HXXU0APD3 PDA: J200HXXU0APE1 Android Version: 5.1.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:06 [Ultimate Samsung Flasher v0.7] |
11-03-2016, 21:10 | #1540 (permalink) |
Freak Poster Join Date: May 2014 Location: Kolkata, India
Member: 2178545 Status: Offline Thanks Meter: 24 | guys tell me one thing for moto frp reset i have to enable usb debug only or there is any other ways ? because if i have to enable usb debugging then i can tick oem unlock from there and reset so no need of any box. is there any other ways to make frp reset of moto in shortcut ??? |
11-04-2016, 07:01 | #1542 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | After frp full flash flash this firmware problem solve J210FXXU0APH2_J210FODD0APH2 after do frp j210f flash compulsory http://forum.gsmhosting.com/vbb/f970...ighlight=j210f |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
11-05-2016, 08:48 | #1544 (permalink) |
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | SM-J210F FRP Reset Done Code: Device: SM-J210F Operation: Apply FRP Patch Port: COM3 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Applying Patch Data... . . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 00:15 [Ultimate Samsung Flasher v0.7] ------------------------------------------ Device: SM-J210F Operation: Reset FRP Searching for Device... Found Model: SM-J210F Baseband: J210FXXU0APF8 Bootloader: J210FXXU0APF1 PDA: J210FXXU0APG1 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:10 [Ultimate Samsung Flasher v0.7] |
11-05-2016, 10:16 | #1545 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | mts m131 unlock done Code: Port : COM81 : ZTE CDMA Handset Diagnostics Interface (COM81) Baud Rate : 921600 Device : ZTE C132 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Nov 13 2013 19:01:55 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.C1 ESN : 80EBC3-- MEID : A1000011823--- Unlocking Security... OK Build : V.MTS.C132.B05 Soft Ver. : SSTL_S183_NL_RBTL40NV1.0.0B02 Detected : C132 User Code : 0000 Checking if Supported for Unlock... OK Setting Download Mode... OK Waiting for Reconnect... OK Preparing Phone... OK Sending Bootloader... OK Initializing Bootloader... OK Initializing Flash Chip... OK Flash Chip : SPANSION S71VS128RC0 Chip Size : 16 MB Unlocking Phone... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:36 Module Ver. [1.6] Log Saved to Logs\161105_142348.log |
