11-19-2015, 07:43 | #151 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | zte s1602 repair meid done Code: Port : COM105 : ZTE CDMA Handset Diagnostics Interface (COM105) Baud Rate : 921600 Device : C132 Operation : Write MEID Opening Port... OK Reading Information... Compile : Apr 12 2011 11:09:05 Release : Apr 24 2009 24:00:00 Hw Ver. : CTYXK_S1 ESN : 00000000 MEID : 00000000000000 Unlocking Security... Failed Build : CTYXK_S193_RNTN01NV1.0.0B04 Software : CTYXK_S193_RNTN01NV1.0.0B04 Detected : CTYXK_S1 User Code : 0000 Writing MEID A0000032xxxxxx... OK New ESN : 80A7xxxx New MEID : A0000032xxxxxx Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.3] Log Saved to Logs\151119_115902.log |
11-19-2015, 11:58 | #152 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | huawei c2830 hang on tata logo recover done Port : COM99 : HUAWEI CDMA Handset - Application Interface (COM99) Baud Rate : 921600 Device : Huawei C2835 Operation : Write APP/EFS Opening Port... OK Preparing Phone... OK Authorizing Download... Denied! Port Closed. Operation Failed! Time Taken: 97:50 Module Ver. [1.0] |
The Following User Says Thank You to rehmani For This Useful Post: |
11-19-2015, 11:59 | #153 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung j100h country unlock done without adb Code: Port : COM136 : SAMSUNG Mobile USB Modem #9 Baud Rate : 115200 Device : Samsung G360H Operation : Unlock Opening Port... OK Reading Information... OK Model : SM-J100H IMEI : 3528280796 Version Info : J100HXXU0AOJ1 : J100HOJV0AOJ1 : J100HXXU0AOJ1 : J100HXXU0AOJ1 Preparing Phone... OK Reading Lock Status... OK Status : SIM Locked* Phone May Be Hard Locked, Unlock May Not Work Reading Lock Levels.. OK Lock Level [0] : Locked Lock Level [1] : Unlocked Lock Level [2] : Unlocked Lock Level [3] : Unlocked Lock Level [4] : Unlocked Resetting Lock Codes... Done UnFreeze : 00712621 Level[1] : 83626762[Locked] Level[2] : 00000000[Unlocked] Level[3] : 00000000[Unlocked] Level[4] : 00000000[Unlocked] Level[5] : 00000000[Unlocked] Port Closed. Operation Finished. Elapsed Time: 00:13 Module Ver. [1.4] Log Saved to Logs\151119_155208.log |
The Following 3 Users Say Thank You to rehmani For This Useful Post: |
11-26-2015, 16:03 | #154 (permalink) |
Product Supporter Join Date: Sep 2015 Location: Moldova
Member: 2465199 Status: Offline Sonork: 100.1669899 Thanks Meter: 248 | Samsung S6 Edge SM-G925F Reactivation Lock Remove Code: Port : COM39 : SAMSUNG Mobile USB Modem #7 Baud Rate : 921600 Device : Samsung Operation : Samsung Reactivation Lock Reset Opening Port... OK Checking for Device in Download Mode... Found Reading Data from Phone... Done Chipset : LSI7420 [High Speed] Checking for Samsung Reactivation Data... Found RL Bit : C4D1 Resetting Samsung Reactivation Data... Done Resetting Phone... Done Port Closed. Operation Finished. Elapsed Time: 00:07 Module Ver. [1.4] Log Saved to Logs\151126_163018.log |
The Following 4 Users Say Thank You to U.M.T Manager For This Useful Post: |
12-02-2015, 18:09 | #157 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Rajasthan (Kota)
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | haier c380 blinking repair successfully Port : COM5 : Qualcomm Diagnostics Interface 3197 (COM5) Baud Rate : 921600 Device : Haier C380 Operation : Flash (Emergency) Opening Port... OK Preparing Phone.. OK Sending Bootloader... OK Executing Bootloader... OK Syncing Phone... OK Initializing Flash Chip... OK Flash Chip : SPANSION S29VS128R Chip Size : 16 MB Firmware : C380_SP_Q1110-HC-C380_R-P1.01.35-S028.bin Fw Size : 16 MB Writing Firmware... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 08:08 Module Ver. [1.3] |
The Following User Says Thank You to yusufali786 For This Useful Post: |
12-02-2015, 18:10 | #158 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | lava l661 blinking repair successfully Port : COM17 : Qualcomm Diagnostics Interface 3197 (COM17) Baud Rate : 921600 Device : Lava L661 Operation : Flash [Emergency] Opening Port... OK Preparing Phone... OK Sending Bootoader... OK Executing Bootloader... OK Initializing Flash Chip... OK Flash Chip : SPANSION S71VS128RB0 Chip Size : 16 MB Firmware : Lava L661_MTS_B02.bin Fw. Size : 16 MB Flashing Firmware... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 09:25 Module Ver. [1.3] |
12-02-2015, 18:11 | #159 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | Samsung b119 security code read successfully Port : COM23 : SAMSUNG HSP Plus Modem Driver Baud Rate : 921600 Device : Samsung B119 Operation : Read Info Opening Port... OK Reading Information... OK Compile : Oct 26 2010 15:40:02 Release : Sep 01 2009 00:00:00 Hw Ver. : SCNNZ317 ESN : 8047XXXX MEID : A000002XXXXXXX Executing Security Unlock... OK Sending SPC (000000)... OK User Code : 0272 Port Closed. Time Taken: 00:07 Module Ver. [1.3] |
12-02-2015, 18:13 | #160 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | Haier cg550 unlock successfully Port : COM25 : Qualcomm HS-USB Diagnostics 9004 (COM25) Baud Rate : 921600 Device : Haier CG550 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Sep 21 2014 16:50:52 Release : Apr 24 2012 05:00:00 Hw Ver. : CG550F00 Reading Extended Information... ESN : 806EBB07 MEID : A1000025CXXXXX IMEI : 35330403249XXXX BT Addr : A69383A80700 BUILD : q11x5-CG108-1030 Lock Code : 0000 Setting Download Mode... OK Reconnecting Phone... OK Preparing Phone... OK Sending Bootloader... OK Executing Bootloader... OK Initializing Flash Chip... OK Flash Chip : INTEL 512 L18 ADMux Chip Size : 64 MB [Main: 32MB, Shadowed: 32MB] Patching Firmware... OK Patching Firmware... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:22 Module Ver. [1.3] |
12-02-2015, 18:27 | #161 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | huawei ec306 unlock successfully Fix nv operation Port : COM39 : HUAWEI Mobile Connect - Application Interface (COM39) Baud Rate : 921600 Device : Huawei EC306 Operation : Fix NV Only Opening Port... OK Reading Information... OK Compile : Nov 9 2013 15:36:36 Release : Mar 12 2011 12:00:00 Hw Ver. : SCAUTHZ3 ESN : 80BXXXXX MEID : A00000435XXXXX Hw. Type : EC306-1CE1EC309M Ver.A Firmware : 11.102.25.02.656 Dashboard : UTPS23.009.17.02.656_MAC23.009.17.02.656 Flash Code : 59083719 Lock Status : Locked RUIM Mode : NV Only Preparing Modem... OK Setting Download Mode... OK Waiting For Reconnect... OK Modem Found : COM44 : HUAWEI Mobile Connect - PC UI Interface (COM44) Opening Connection... OK Verifying Boot Mode... OK Bootloader : Q62xx-OSBL Device : HUAWEI EC306 Patching Required Data... OK Resetting Modem... OK Port Closed. Operation Finished. Time Taken: 00:45 Module Ver. [1.3] unlock Port : COM46 : HUAWEI Mobile Connect - 3G Application Interface (COM46) Baud Rate : 921600 Device : Huawei EC306 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Nov 9 2013 15:36:36 Release : Mar 12 2011 12:00:00 Hw Ver. : SCAUTHZ3 ESN : 00000000 MEID : 00000000000000 Hw. Type : EC306-1CE1EC309M Ver.A Firmware : 11.102.25.02.656 Dashboard : UTPS23.009.17.02.656_MAC23.009.17.02.656 Flash Code : 34528025 Lock Status : Locked RUIM Mode : NV Only Unlocking Modem... OK Trying to Read SPC... Failed to Read! Using Default SPC [000000]... OK Changing RUIM Mode Setting... OK RUIM Mode : RUIM Only Port Closed. Operation Finished. Time Taken: 00:05 Module Ver. [1.3] write meid Port : COM46 : HUAWEI Mobile Connect - 3G Application Interface (COM46) Baud Rate : 921600 Device : Huawei EC306 Operation : Write MEID Opening Port... OK Reading Information... OK Compile : Nov 9 2013 15:36:36 Release : Mar 12 2011 12:00:00 Hw Ver. : SCAUTHZ3 ESN : 00000000 MEID : 00000000000000 Hw. Type : EC306-1CE1EC309M Ver.A Firmware : 11.102.25.02.656 Dashboard : UTPS23.009.17.02.656_MAC23.009.17.02.656 Flash Code : 34528025 Lock Status : Unlocked RUIM Mode : RUIM Only Executing Security Unlock Method (1)... OK Writing MEID [A00000435XXXXX]... OK New MEID : A00000435XXXXX Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.3] after all successfull unlock Port : COM46 : HUAWEI Mobile Connect - 3G Application Interface (COM46) Baud Rate : 921600 Device : Huawei EC306 Operation : Read Info Opening Port... OK Reading Information... OK Compile : Nov 9 2013 15:36:36 Release : Mar 12 2011 12:00:00 Hw Ver. : SCAUTHZ3 ESN : 00000000 MEID : A00000435XXXXX Hw. Type : EC306-1CE1EC309M Ver.A Firmware : 11.102.25.02.656 Dashboard : UTPS23.009.17.02.656_MAC23.009.17.02.656 Flash Code : 59083719 Lock Status : Unlocked RUIM Mode : RUIM Only Operation Finished. Port Closed. Time Taken: 00:01 Module Ver. [1.3] Log Saved to Logs\151202_225643.log |
12-03-2015, 10:43 | #162 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | zte m131 1 click unlock Port : COM235 : ZTE CDMA Handset Diagnostics Interface (COM235) Baud Rate : 921600 Device : ZTE M131 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Dec 23 2013 09:50:22 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.M1 ESN : 8041XXXX MEID : A0000038AXXXXX Unlocking Security... OK Build : V.MTS.M131.B02 Soft Ver. : SSTL_S183_FCM_RBTL40NV1.0.0B04 Detected : M131 User Code : 0000 Checking if Supported for Unlock... OK Setting Download Mode... OK Waiting for Reconnect... OK Preparing Phone... OK Sending Bootloader... OK Initializing Bootloader... OK Initializing Flash Chip... OK Flash Chip : SPANSION S71VS128RC0 Chip Size : 16 MB Unlocking Phone... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:21 Module Ver. [1.3] Log Saved to Logs\151203_145841.log |
12-05-2015, 05:27 | #163 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | Zte N855D 1 Click unlock Code: Port : COM53 : ZTE Handset Diagnostic Interface (COM53) Baud Rate : 921600 Device : ZTE N855D Operation : Unlock Opening Port... OK Reading Information... OK Compile : Aug 13 2013 01:18:49 Release : Jun 11 2012 01:00:00 Hw Ver. : USMEKMLY MEID : A1000035XXXXXX Reading Lock Data... OK Lock Status : Locked Unlocking Phone... OK Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.3] |
The Following 2 Users Say Thank You to yusufali786 For This Useful Post: |
12-05-2015, 05:29 | #164 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | Zte s165 repair security Code: Port : COM42 : ZTE CDMA Handset Diagnostics Interface (COM42) Baud Rate : 921600 Device : S165 Operation : Write MEID Opening Port... OK Reading Information... Compile : Apr 10 2012 15:17:30 Release : Apr 24 2009 24:00:00 Hw Ver. : RIC_S165 ESN : 00000000 MEID : 00000000000000 Unlocking Security... OK Build : RIC_S165_RBTL21NV1.0.0B02 Software : SSTL_S165_SP_RBTL40NV1.0.0B03 Detected : S165 User Code : 0000 Writing MEID A0000043XXXXXX... OK New ESN : 80BA1XXX New MEID : A0000043XXXXXX Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.3] |
12-10-2015, 07:06 | #165 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | LG rd3500 1 click unlock Code: Port : COM269 : LGE CDMA USB Serial Port (COM269) Baud Rate : 38400 - Auto Device : LG RD3500 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Dec 27 2007 16:27:15 Release : Dec 27 2007 23:00:00 Hw Ver. : RD350F08 ESN : 80D2A9C5 MEID : A0000007EF1520 Model : RD3500 Software : F08 Preparing Data... OK Setting Offline Mode... OK Security Unlock... OK Setting Download Mode... OK Preparing Bootloader... OK Sending Bootloader... OK Executing Bootloader... OK Erasing Flash Memory... OK Erasing Flash Memory... OK Writing Flash Memory... OK Writing Flash Memory... OK Resetting Phone... OK Port closed. Operation Finished. Time Taken: 00:26 Module Ver. [1.3] Log Saved to Logs\151210_113457.log |
