05-14-2021, 10:54 | #10021 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | Operation : Reset FRP Searching for COM1.0 Device...Found! COM10 : HUAWEI USB COM 1.0 (COM10) Opening Port...OK Platform : Kirin_710 Sending Loader...[1]..[2]..[3]..Done Reading Partition Table...Done Erasing FRP Data...Done Hold power button to reboot device. Operation Finished. UltimateHST v0.2 |
05-14-2021, 10:54 | #10022 (permalink) |
Member: 614304 Status: Offline Thanks Meter: 150 | Huawei P Smart 2019 / kirin710 / frp / ultimatehst / DONE by Testpoint ! Operation : Reset FRP Searching for COM1.0 Device...Found! COM10 : HUAWEI USB COM 1.0 (COM10) Opening Port...OK Platform : Kirin_710 Sending Loader...[1]..[2]..[3]..Done Reading Partition Table...Done Erasing FRP Data...Done Hold power button to reboot device. Operation Finished. UltimateHST v0.2 |
05-15-2021, 18:09 | #10025 (permalink) |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | dup-lx1 frp Device : Huawei Y7 Prime (DUB-LX1) Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM35) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 65001500 OPK_DATA : 3B48AE9023196AE5C8162BCE65CB66E9636C784CB52A55046D 15110FD8B11688 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_030]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, EMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : unknown Software : System 8.2.0.036(1UWB) [Mon Feb 8 18:27:38 CST 2021] Android Ver. : 8.1.0 Patch Level : 2020-09-01 Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 6.7 |
The Following User Says Thank You to boganice For This Useful Post: |
05-15-2021, 18:09 | #10026 (permalink) |
05-16-2021, 20:11 | #10027 (permalink) |
Member: 5184 Status: Offline Thanks Meter: 246 | REDMI 9 MI Account remove 1 Click + FRP via UMTMTKv4.2 MI Remove: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM9 Port Name: MediaTek USB Port_V1632 (COM9) Path: \\?\usb#vid_0e8d&pid_0003#6&944c330&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0707, [MT6768] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM9) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Userdata is NOT ENCRYPTED Seeking Mi Account Data... Resetting Mi Account... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] ===== FRP Remove: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM9 Port Name: MediaTek USB Port_V1632 (COM9) Path: \\?\usb#vid_0e8d&pid_0003#6&944c330&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0707, [MT6768] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM9) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Userdata is NOT ENCRYPTED Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
05-16-2021, 20:12 | #10028 (permalink) |
05-19-2021, 03:19 | #10029 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 147 | Oppo Reno Z FRP Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM17 Port Name: MediaTek USB Port (COM17) Path: \\?\usb#vid_0e8d&pid_0003#5&2e40154&0&9#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0725, [MT6779] Hardware Info: 0x8A00, 0xCA01, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM17) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : UFS Reading Device Information... Manufacturer : OPPO Build Flavor : full_oppo6779_18593-user Build Desc. : full_oppo6779_18593-user 9 PPR1.180610.011 eng.root.20191021.203323 release-keys Android Ver. : 9 Patch Level : 2019-10-05 Platform : MT6779 Board : oppo6779_18593 Platform : mt6779 Platform : MT6779 Board : oppo6779_18593 Platform : mt6779 Userdata is NOT ENCRYPTED Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
The Following User Says Thank You to mtb116 For This Useful Post: |
05-19-2021, 03:22 | #10030 (permalink) |
05-19-2021, 15:35 | #10031 (permalink) |
Freak Poster Join Date: May 2020 Location: Globe
Member: 2955840 Status: Offline Thanks Meter: 83 | HONOR 7A JOB DONE Device : Huawei Honor 7A (AUM-L29) Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM100) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00400 [8937] 41001500 OPK_DATA : 3B48AE9023L9g3hbRb2SNjTqULWtLYGqPwfajsxzwfw046D151 10FD8B11688 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_034]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, EMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : unknown Software : System 8.0.0.059(000E), eng.root.20180601.173812 [Fri Jun 1 17:38:12 CST 2018] Android Ver. : 8.0.0 Patch Level : 2018-06-01 Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 6.8 |
The Following User Says Thank You to Chijohn For This Useful Post: |
05-19-2021, 15:35 | #10032 (permalink) |
05-19-2021, 18:41 | #10033 (permalink) |
No Life Poster Join Date: Apr 2005 Location: ALGERIA Age: 42
Member: 135661 Status: Offline Thanks Meter: 92 | Redmi note 10 FRP Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM19) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1500900 [SM6150] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6150]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...OK Detecting Chip Type...OK Hardware : SM6150, UFS, 64 GB LU Count : 6 [0x00DD4000] [0x00000800] [0x00000800] [0x00008000] [0x00100000] [0x00008000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Software : , V12.0.5.0.RKGMIXM [Mon Mar 29 06:43:53 CST 2021] Android Ver. : 11 Patch Level : 2021-03-01 Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 6.8 |
The Following User Says Thank You to zaki_barika For This Useful Post: |
05-19-2021, 18:41 | #10034 (permalink) |
Member: 135661 Status: Offline Thanks Meter: 92 | Redmi note 7 MI ACCOUNT Operation : Reset Mi Account (New) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM19) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...OK Detecting Chip Type...OK Hardware : MSM8996, EMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Software : QKQ1.190910.002 V12.0.1.0.QFGMIXM, V12.0.1.0.QFGMIXM [Fri Oct 23 20:42:11 WIB 2020] Android Ver. : 10 Patch Level : 2020-10-01 Reading Data[1]...Done Patching Data...Done Writing Data...Done Reading Data[2]...Done Writing Data...Done Operation Finished. QcFire Ver. 6.8 |
