10-25-2016, 07:59 | #1471 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung s7582 flash done Code: Device: GT-I8190 Operation: Flash Firmware Port: COM39 : SAMSUNG Mobile USB Modem #4 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: KyleProD [HiSpeed] Sending Partition [KERNEL]... Done Sending Partition [RECOVERY]... Done Sending Partition [DTS]... Done Sending Partition [modem]... Done Sending Partition [CSC]... Done Sending Partition [HIDDEN]... Done Sending Partition [system]... Done Sending Partition [PARAM]... Done Closing Session... Done Operation Finished. Elapsed Time: 05:32 [Ultimate Samsung Flasher v0.7] |
10-25-2016, 08:17 | #1472 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung b319 write security and unlock done Code: Port : COM72 : SAMSUNG HSP Plus Modem Driver Baud Rate : 921600 Device : Samsung B319 Operation : Read Info Opening Port... OK Reading Information... OK Compile : Aug 27 2009 18:27:56 Release : Mar 29 2007 20:00:00 Hw Ver. : SCNNZ317 ESN : B0000000 MEID : 00000000000000 Executing Security Unlock... OK Sending SPC (000000)... OK User Code : 0000 Port Closed. Operation Finished. Time Taken: 00:09 Module Ver. [1.6] Log Saved to Logs\161025_124556.log Port : COM72 : SAMSUNG HSP Plus Modem Driver Baud Rate : 921600 Device : Samsung B319 Operation : Write MEID Opening Port... OK Reading Information... OK Compile : Aug 27 2009 18:27:56 Release : Mar 29 2007 20:00:00 Hw Ver. : SCNNZ317 ESN : B0000000 MEID : 00000000000000 Executing Security Unlock... OK Reading SPC... OK Sending SPC [000000]... OK Writing MEID [A000001D0A----]... OK New ESN : 8005E1-- New MEID : A000001D0A---- Port Closed. Operation Finished. Time Taken: 00:03 Module Ver. [1.6] Log Saved to Logs\161025_124604.log Port : COM72 : SAMSUNG HSP Plus Modem Driver Baud Rate : 921600 Device : Samsung B319 Operation : Read Info Opening Port... OK Reading Information... OK Compile : Aug 27 2009 18:27:56 Release : Mar 29 2007 20:00:00 Hw Ver. : SCNNZ317 ESN : 8005E1-- MEID : A000001D0----- Executing Security Unlock... OK Sending SPC (000000)... OK User Code : 0000 Port Closed. Operation Finished. Time Taken: 00:07 Module Ver. [1.6] Log Saved to Logs\161025_124655.log Code: Port : COM17 : USB Serial Port (COM17) Baud Rate : 9600 [Auto] Device : Samsung B229 Operation : Unlock Opening Port... OK Setting Test Mode... OK Step 1... OK Step 2... OK Step 3... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:11 Module Ver. [1.6] Log Saved to Logs\161025_124213.log |
10-25-2016, 14:15 | #1473 (permalink) |
Insane Poster Join Date: Mar 2008 Location: mahesana.guj.india Age: 41
Member: 737752 Status: Offline Sonork: [email protected] Thanks Meter: 8 | motorola xt1562 frp not unlock Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Qualcomm FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 0.5 Product : lux Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Failed Operation Failed. Elapsed Time: 00:04 [Module Ver. 3.1] Log Saved to Logs\161025_184240.log plz help |
10-25-2016, 14:22 | #1474 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung s5830i format done Code: Port : COM75 : SAMSUNG Mobile USB Modem #11 Baud Rate : 115200 Device : Samsung G361H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : GT-S5830i IMEI : 35230605458---- Version Info : S5830iXXKL1 : S5830iOXEKK4 : S5830iXXKK5 : S5830iXXKL1 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:12 [Module Ver. 3.1] Log Saved to Logs\161025_185026.log |
The Following User Says Thank You to rehmani For This Useful Post: |
10-25-2016, 14:52 | #1475 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung sm-j210f frp remove umt Code: Device: SM-J210F Operation: Apply FRP Patch Port: COM3 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Applying Patch Data... . . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 00:20 [Ultimate Samsung Flasher v0.7] Code: Device: SM-J210F Operation: Reset FRP Searching for Device... Found Model: SM-J210F Baseband: J210FXXU0APF8 Bootloader: J210FXXU0APF1 PDA: J210FXXU0APH2 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:09 [Ultimate Samsung Flasher v0.7] |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
10-26-2016, 07:08 | #1476 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung j100f flash done Code: Device: GT-I8190 Operation: Flash Firmware Port: COM69 : SAMSUNG Mobile USB Modem #7 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: PXA1L88 [HiSpeed] Sending Partition [KERNEL]... Done Sending Partition [CACHE]... Done Sending Partition [DTimPrimary]... Done Sending Partition [DTimRecovery]... Done Sending Partition [HIDDEN]... Done Sending Partition [LOKE1ST]... Done Sending Partition [LOKE2ND]... Done Sending Partition [MODEM]... Done Sending Partition [RECOVERY]... Done Sending Partition [SBOOT2]... Done Sending Partition [SBOOT]... Done Sending Partition [SYSTEM]... Done Closing Session... Done Operation Finished. Elapsed Time: 03:48 [Ultimate Samsung Flasher v0.7] Port : COM76 : SAMSUNG Mobile USB Modem #12 Baud Rate : 115200 Device : Samsung G361H Operation : Read Info Opening Port... OK Reading Information... OK Model : SM-J100F IMEI : 3579450656----- Version Info : J100FXXU0APB1 : J100FOJV0APB1 : J100FXXU0APB1 : J100FXXU0APB1 Port Closed. Operation Finished. Elapsed Time: 00:04 [Module Ver. 3.1] Log Saved to Logs\161026_113730.log |
10-26-2016, 10:41 | #1477 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung a500f unlock done Code: Port : COM78 : SAMSUNG Mobile USB Modem #13 Baud Rate : 115200 Device : Samsung G361H Operation : Read Info Opening Port... OK Reading Information... OK Model : SM-A500F IMEI : 35421807070---- Version Info : A500FXXU1B1 : A500FOJV1B1 : A500FXXU1BOJ5 : A500FXXU1B1 Port Closed. Operation Finished. Elapsed Time: 00:05 [Module Ver. 3.1] Log Saved to Logs\161026_143601.log Port : COM14 : SAMSUNG Mobile USB Serial Port (COM14) Baud Rate : 115200 Device : Samsung A500FU Operation : Unlock Opening Port... OK Reading Phone Information... OK Compile : Oct 30 2015 21:00:14 Release : Oct 15 2015 00:00:00 Hw. Ver. : EAAAANVZ ESN : B0000000 MEID : 00000000000000 IMEI : 35421807070---- Switching to Offline Mode... OK Preparing Phone... OK Unlocking Phone, Please wait... OK Resetting Phone... OK If Phone does not restart, do it manually. Port Closed. Operation Finished. Elapsed Time: 00:04 [Module Ver. 3.1] Log Saved to Logs\161026_151031.log |
10-26-2016, 17:09 | #1478 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung sm-g530h format Port : COM27 : SAMSUNG Mobile USB Modem #2 Baud Rate : 115200 Device : Samsung G530H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : SM-G530H IMEI : 3565540+++++++ Version Info : G530HXXU2AOA2 : G530HODD2AOA1 : G530HDDU2AOA1 : G530HXXU2AOA2 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:08 [Module Ver. 3.1] Log Saved to Logs\161026_213450.log |
10-27-2016, 06:37 | #1479 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g531f frp remove done Code: Device: GT-I8190 Operation: Reset FRP / RL / EE Port: COM69 : SAMSUNG Mobile USB Modem #3 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: PXA1L88 [HiSpeed] Resetting FRP Lock Data... Done Elapsed Time: 00:07 [Ultimate Samsung Flasher v0.7] Port : COM70 : SAMSUNG Mobile USB Modem #4 Baud Rate : 115200 Device : Samsung G361H Operation : Read Info Opening Port... OK Reading Information... OK Model : SM-G531F IMEI : 35230207693---- Version Info : G531FDDU1AOH2 : G531FODD1AOH2 : G531FDDU1AOH1 : G531FDDU1AOH2 Port Closed. Operation Finished. Elapsed Time: 00:05 [Module Ver. 3.1] Log Saved to Logs\161027_110728.log |
10-27-2016, 09:03 | #1480 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lenovo atmos frp reset done Code: Port : ADB Interface Baud Rate : Not Applicable Device : Generic Operation : Motorola FRP Reset Searching for Device... Found Model : Lenovo X3a40 Version : 6.0.1 Hardware : qcom Baseband : MPSS.BO.2.6.c1.4-00032 SIM Card : ABSENT,ABSENT CPU : arm64-v8a Type : Unknown MEID(1) : Null/Empty Root : Not Rooted Resetting FRP Lock... Done Operation Finished. Elapsed Time: 00:12 [Module Ver. 3.1] Log Saved to Logs\161027_133113.log |
10-27-2016, 09:15 | #1481 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | ASUS_Z00LD Motorola FRP Reset Port : ADB Interface Baud Rate : Not Applicable Device : Generic Operation : Motorola FRP Reset Searching for Device... Found Model : ASUS_Z00LD Version : 6.0.1 Hardware : qcom Baseband : 202c10_11.1.0_160802 SIM Card : ABSENT,ABSENT CPU : arm64-v8a Type : Unknown MEID(1) : Null/Empty Root : Not Rooted Resetting FRP Lock... Done Operation Finished. Elapsed Time: 00:07 [Module Ver. 3.1] |
10-27-2016, 10:35 | #1482 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Micromax d321 imei repair Port : COM35 : MTK CDC Serial (COM35) Baud Rate : 921600 Device : MTK Android Operation : IMEI Repair (META) Opening Port... OK Reading Phone Information... Done CPU : MT6572, E01 Software : MOLY.WR8.W1315.MD.WG.MP.V36 Hardware : TINNO72_WE_72_KK_HSPA_HW Reading Data.... Done Writing IMEI[1] 911418358++++++.... Done Writing IMEI[2] 911418359++++++.... Done Operation Finished. Elapsed Time: 00:03 [Module Ver. 3.1] Log Saved to Logs\161027_145738.log |
10-27-2016, 10:57 | #1483 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | zte d286 unlock done Code: Port : COM76 : Qualcomm HS-USB Diagnostics 9004 (COM76) Baud Rate : 921600 Device : Lava D286 (ZTE) Operation : Unlock Opening Port... OK Reading Information... OK Compile : Dec 25 2013 12:58:23 Release : Apr 24 2012 05:00:00 Hw Ver. : UP105D13 ESN : 8024BB-- MEID : A0000038AE9--- IMEI : 862307029655--- BUILD : q11x5-CG108-1030 Reading Extended Information... OK User Code : 0000 SPC : 000000 Setting Download Mode... OK Waiting For Reconnect... OK Preparing Phone... OK Sending Bootloader... OK Executing Bootloader... OK Initializing Flash Chip... OK Chip Name : INTEL 512 L18 ADMux Chip Size : 64 MB Patching Firmware... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:39 Module Ver. [1.6] Log Saved to Logs\161027_152533.log |
10-27-2016, 14:52 | #1484 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1006228 Status: Offline Thanks Meter: 4 | Device: SM-J200G Operation: FRP Reset Package Processing Reset Package... Done Port: COM25 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Applying Reset Package... Done Closing Session... Done Operation Finished. Elapsed Time: 00:11 [Ultimate Samsung Flasher v0.7] Reset Package Applied. Now you can reset FRP. Device: GT-I8190 Operation: Reset FRP / RL / EE Port: COM220 : SAMSUNG Mobile USB Modem #84 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-J200G IMEI: 3584270xxxxx Software: J200GDDU1APH5/J200GODD1APH1/J200GDDU1APH2/J200GDDU1APH5 Init Download Mode... OK Port: COM25 : SAMSUNG Mobile USB Modem #2 Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Resetting FRP Lock Data... Done Elapsed Time: 00:51 [Ultimate Samsung Flasher v0.7] |
10-27-2016, 14:53 | #1485 (permalink) |
Member: 1006228 Status: Offline Thanks Meter: 4 | Device: SM-J210F Operation: Apply FRP Patch Port: COM185 : SAMSUNG Mobile USB Modem #61 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Applying Patch Data... . . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 00:21 [Ultimate Samsung Flasher v0.7] Device: SM-J210F Operation: Reset FRP Searching for Device... Found Model: SM-J210F Baseband: J210FXXU0APF8 Bootloader: J210FXXU0APF1 PDA: J210FXXU0APH2 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:09 [Ultimate Samsung Flasher v0.7] |
